Toshiba 2938xp crt tv vertical deflection fail and i want diagram
  • srivenkates Apr 16, 2009
    Thanks for your coperation, but vertcal ic is TA 8427 I want sum tips and impartent chek points
  • 4,234 Answers
I don't have access to the manuals for your specific model, but vertical failures are usually the result of poor connections at the vertical IC or a defective IC. Look for a small flat IC attached to a heat sink with about 9-11 pins. It may be marked LA7837 or something similar. Resolder the pins first. If that doesnot resolve the problem, change the IC.
Keep us posted,
Dan
Posted on Apr 15, 2009
  • ABRsvcs Apr 16, 2009
    I don't have the schematics, but rarely are they required. If the resolder failed to resolve the problem replace the TA8427 and try again. At that point the vertical should return. It may not be 100% resolves as there are capacitors in the same circuit that fail as well. This would show up as a distorted picture in the vertical direction. Look for caps with values between 47ufd and 100ufd in the same circuit and check or replace them.
    Keep us posted.
    Dan
I have a thin line in my tv and i dont know what ic no.to replace?
The fault is a failure of the deflection circuit and since you have not specified whether it is a vertical or an horizontal line the section failed will be related to the position of the line.
If horzontal the vertical IC or the section related is faulty and if Vertical the horizontal section., Now this can be the deflection IC, teh deflection coils or even discrete components like capacitors or resisitors in this section which will require a signal trace with a voltage test before the absence of the sync pulses are confirmed and the section identified.
I request not to change the IC unless it is proved but you can solder the vertical IC or the section concerned -- if there is dry soldering.
Aug 25, 2011 | Toshiba 32A50 32" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
No vertical deflection, just a line in the center. I don´t have the diagram. Tanks
Look up for faulty Elkos in the vertical Stage near the powersuply abd then find the Vertical IC with are fit near by the highvoltagetransitor
Sep 05, 2009 | Daewoo DTQ-13P2FC 13" TV
9 year old Toshiba TV. The picture is totally
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Jun 25, 2009 | Toshiba Televison & Video
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
No vertical deflection Toshiba model #CF27H40, need schematic
If this is a CRT television, replace all electrolytic capacitors in the vertical circuit - this fixes 90% of all vertical deflection problems. The capacitors most likely t0 fail are low-cap, high-volt such as 3.3 uF at 50 volts, etc. Quicker and cheaper to replace them all, rather than tracing it down to the one bad part. Total cost if you do it yourself is about $15 tops, and make sure you install them correctly - electros have a plus and minus lead, and must not be installed backwards or you'll have serious blow-upage of the new parts. Before replacing the caps, however, go over all solder joints in the vertical section, reheat them and add a touch of fresh solder. You may end up not needing to replace anything.
Dec 21, 2008 | Toshiba 36AF41 36" TV
Toshiba television
Your Vertical Deflection circuit has failed. Generally this is an easy fix, providing the part is still available. It will require the attention of a qualified repair technitian.
Mar 11, 2008 | Televison & Video
Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Mar 05, 2008 | Sharp Televison & Video
Vertical deflection
The problem may have been caused by the Vertical Filter Capacitors located in the immediate area of the deflection chip. If this is the case, and the chip you replaced was bad, you may infact, have another bad chip. You need to check for a shorted capacitor before rechanging the chip again. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Toshiba 30HF85 30" TV
Toshiba CZ32T31, Vertical Deflection?
Usually the solder joints on the vertical output IC crack and the little pico-fuse opens. Resoldering the IC and replacing the pico fuse should bring the picture back. If you have never heard of these parts before and have no idea how to find them, then allow a qualified tech to handle it for you.
Aug 09, 2007 | Toshiba CZ32T31 TV
Televison & Video Logo
304 people viewed this question
Top Televison & Video Experts
Electro Med Services...
