Question about Tefal Avante Deluxe 4 Slice Toaster
I have a Tefal 5327-15 Avanti Deluxe 4-Slice Toaster which came without a user guide and I don't know which buttons do what? or what the lights are for?
5 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: can you email the user manual for tefal toaster
Hello Val,
Here's the link directly to Tefal's site where you can select the exact toaster manual from the list provided. I wasn't sure of the exact model, since Tefal has two (2) Avante Deluxe model toasters available (both a 2 and 4 slice version) and sometimes the Fixya site only has a limited selection for certain products for users to request assistance with.
In any case, they are all on the page at the link below. Simply click and you'll get a free manual that you can save or print out for your use and future reference.
http://www.t-falusa.com/tefal/Consumer_service/Use_instructions/HomeUseInstructionsTemplateFile.aspx?NRMODE=Published&NRNODEGUID=%7bC41F9AC8-8DCD-439E-8171-0CA2B8E9C7E3%7d&NRORIGINALURL=%2fConsumer%2bservice%2fUse%2binstructions%2fuse-instructions_home%2ehtm&NRCACHEHINT=NoModifyGuest
If it doesn't come up, simply select "toasters" from the pull down window on the screen and hit "go"
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to search the web for them.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
SOURCE: tefal avanti hi speed 4 slice toaster one side not
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Posted on Aug 19, 2010
eugbug
  • 479 Answers
SOURCE: I have lost the manual for my tefal avanti deluxe
The instructions can be downloaded here:
http://www.tefal.co.uk/NR/rdonlyres/89C9BBE6-235A-4142-B9E4-9D5C115AD973/0/Avanti1.pdf
Posted on Mar 15, 2011
kebah
  • 683 Answers
SOURCE: Where can I get operating instructions for the
Hi there.
I have seen an Avante Deluxe 4-Slice Toaster Owner's Manual at http://www.t-falusa.com
You can download this if it matches the model of your toaster.
Regards.
Posted on Jul 19, 2011
Manual download
Here is the tefal home page for the classic 4 slice toaster. I believe it is the same taoster as you have described but let me kow if it isn't.
At the bottom of the page is a downloadable pdf manual for this toaster.
http://www.tefal.co.uk/Breakfast/Toasters/Tefal-Avanti-Classic-4-Slice/p/1500532718
Hope this helps
Jan 29, 2014 | Tefal 5332002 4Slice Toaster
Where can I get operating instructions for the Tefal 5327-16 four slice electric toaster?
Hi there.
Regards.
Jul 18, 2011 | Kitchen Appliances - Others
Can you email the user manual for tefal toaster , please.
dont have one,but you may be able to find one at-kitchen.manualsonline.com,
Oct 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
How to operate it
web search -tefal avanti toaster operating instructions- 7th site down to download instructions
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
I NEED THE MANUAL
Hello Val,
Dec 11, 2009 | Hobart ET27 4-Slice Toaster
Can you email the user manual for tefal toaster avanti deluxe for me to download please
Hello Val,
Nov 23, 2009 | Tefal Avante Deluxe 4 Slice Toaster
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Tefal Avante Deluxe 4 Slice Toaster Logo
153 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
