Question about Sharp Microwave Ovens
Sharp Combi Microwave oven LCD does not work
Sharp Combi Microwave oven R953(SL)M
Everything works fine except LCD screen which should show timing, mode etc. The green panel lights up and shows one black vertical line so one cannot programme it.
I picked this expensive looking stainless steel oven, lovely cond. up for free at the local re-cycling centre. What makes me sick is that someone had to throw it away just because of this fault.
Looking on the net others were complaining of the same fault in similar Sharp ovens.
I contacted local Trading Standards Office and their reply was illuminating: apart from the usual guarantees, products must be fit for normal use up to 6 years - if the fault is 'inherent/genetic then they should fix it or replace it within the 6 year limit. That is in the UK of course.
I am so determined that big companies should not get away with built in faults that I intend to persue this matter.
Thanks for any help you can provide.
Sonia Gwilliam
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 25, 2007
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 18, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Posted on Feb 02, 2010
Testimonial: "Thank you. I will check it out and then decide whether to repair or replace."
I have a Sharp 963 combi oven.. The microwave has stopped heating everything else is working.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
Aug 01, 2011 | Sharp R-963 Convection/Microwave Oven
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Oct 24, 2009 | Sharp R-510HW Microwave Oven
Sharp R-963 900 Watts Convection / Microwave Oven does not heat
This isn't exactly a solution but information that might help other Sharp product owners.
I acquired a Sharp Combi Microwave oven - an expensive looking stainless steel piece of equipment. All works except the LCD screen. It seems that others have this problem too. I am not sure of the guarantee BUT In the UK I phoned the Trading Standards Officer and his info is very interesting indeed:
Apart from the normal guarantees, any equipment sold should have a normal useful life of 6 YEARS! Therefore if the item has a 'generic or 'inherent' fault the cmpany should repair or replace the item up to the 6 year period.
This was news to me!
Why should companies sell expensive stuff when the is something just waiting to go wrong? They just shrug their shoulders and say it is out of guarantee! In the UK, at least, that is not quite the end of story.
So I intend to chase up Sharp and see what they have to say about the fault on mine.
Ralfwil
Apr 06, 2009 | Sharp R-963 Convection/Microwave Oven
Manual for Sharp Carousel R-9A53
There is a sharp site that gives operations manuals that you can print as a PDF. I have checked and the closest offered appears to be an R953 (No A) see if this helps. go to http://www.sharp.co.uk/page/downloaddrivermanuals
Use the click here option under Operations Manuals and then either put in the product code R953 or search through the drop down products to see if there is one that closer matches your needs
Feb 15, 2009 | Sharp Microwave Ovens
Instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
Dec 27, 2008 | Microwave Ovens
Sharp r-1481 950 Watt microwave oven problen
Found the answer by calling a Sharp technician and they said it was the magnetron tube, which is not worth fixing :( Thought I'd pass this on to anyone that has yet to find out.
Oct 15, 2008 | Sharp R-1481B Microwave Oven
Sharp R953
Who is CIS?
Info on ordering Sharp UK parts / spares is here.
Sep 23, 2008 | Microwave Ovens
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
