Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Check Water Supply display lights up
Hi I own a Bosch SGS45C02G Full DW which is 11 months old. I now have a problem where the "Check water supply" display lights up when I turn the dishwasher on. This first appreared when there was 49 minutes left. I have taking all the pipes apart to ensure there is no blockage & happy with that. Also check there were no kinks. The washing works & the dishwasher is connected to the same water supply, so I assume no issues there. Is there anything else I should check? Appreciate your help Kind Regards Gerry
  • Bosch Master
  • 3,382 Answers
It sounds like there is a filter or screen on the water inlet that is partially clogged, check for that.
Posted on May 17, 2017
5 Suggested Answers
SOURCE: bosch shv55mo3gb
use this link then click on insruction manual download type in the model number remember 0 is a number.I know that sounds condesending but i forgot. I used the manual with the ending aus.
http://www.bshappliancecare.com/Bosch/Bosch_dishwasher_manual.html
Posted on Jul 01, 2008
BIKER T
  • 909 Answers
SOURCE: water not pumped out of dishwasher
To cut a long story short, lower the drain pipe as close to the floor as you can. Some dish washers have a non return rubber which holds the water in the cabinet until asked to drain.Meaning water wont just flow out with pipe being low.(Im assuming the drain pump is operating correctly).Check if this alteration makes any difference.
Posted on Nov 13, 2009
SOURCE: Just installed bosch exxcel and light on saying
noavatar_s.gif Nzimpofu
Rank: Apprentice
Rating: 100%, 1 votes
Have been struggling with the same problem. Tipping the machine backwards worked. Many thanks.
Was this helpful? Yes No2 people thought this was helpful
noavatar_s.gif klaudiatombo
Rank: Apprentice
Rating: 100%, 2 votes
I solved the problem, by tipping the dishwasher back about 45degrees, I think this re-adjusted the flood sensor, and it is now working fine. Thank you
Posted on Jan 29, 2010
SOURCE: Dishwasher not draining E25 error code (Bosch
Gr8 stuff klaudi & Nypmh - rocking it back 45% worked a treat.
Bloody Bonza
Shell XX
Posted on Dec 03, 2012
Bosch f17 falt
Your machine is taking to long to fill
Check your water supply is turned full on
also check the filter in the water inlet hose
check to see if your hose is kinked
if all above is ok then it could be a faulty inlet valve
Mar 07, 2015 | Bosch Washing Machines
Bosch silence plus 50 dba is showing error code h01
I believe this is a filling or water flow error. Make sure all the plumbing stuff is OK look at the valve under the sink that feeds the dishwasher. make sure it has not gotten turned off. Sometimes with hot water and cold also a chunk of crud will break off somewhere and get lodged blocking or restricting the flow. You may also have a filter somewhere on the DW to prevent junk from getting in. If there is a piece of crud a likely spot for it to be is at the valve connection under the sink where the DW hose connects to the hot water line. You can try unhooking the DW supply hose from the shut off(turn the shut off OFF first) and seeing if there is any junk in it. Shake the hose about 8" back from the end to try and send any junk in it flying across the kitchen. Also open the valve a bit with a bowl under it to blast any junk out. also see if it seems like a decent amount of water comes out to rule out any upstream plumbing issues.
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Miele G 646 SC, Leaking.? My Miele G646SC is leaking, the red inlet/drain light is on and I suspect it may be one of the pump seals has perished. The machine is 11 yrs old and has never had a problem of...
The dishwasher must be removed from the counter so you can gain access to the pump. I would check with a parts supply company first to see if the pump is still available, and the cost. It may be too expensive to repair a dishwasher that old.
Removing the dishwasher is not very hard. Turn off the electrical breaker. detach the DW from the counter. Pull out. disconnect the water supply and drain. disconnect power supply if required.
Nov 28, 2017 | Miele 24 in. G646SC Plus Free-Standing...
Bosch she43f15uc just stopped pumping water. Any ideas? it is only 18 months old.
My Bosch dishwasher had the same problem. After checking the over flow pan I removed the inlet hose to check water flow. There was none. I checked my cut off valve...open...I had water at the kitchen facet...scratch my head...I looked closer at the Bosch supplied braided water hose. It is directional (label indicating which end to hook to supply)....closer inspection reveals maybe there is a back flow valve in that side of the braided hose. Disconnect, blow air through...air passes freely...reconnect and bingo water flow at the dishwasher. In line back flow valve...can you imagine what a repair man would have charged for that?
Apr 04, 2012 | Dishwashers
I have a 250SX aquastar Bosch tankless hot water heater . It keeps going out on EC code; whats wrong? Also I've been running the unit for about a 9 months without hooking up the condensate dain line.
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Housekeeper put dish washing soap in - machine is full of bubbles. How do I clean it out without flooding the kitchen?
Turn off the hot water supply to the DW. Take a pot or pan. Fill the DW tub with COLD water, pump it out. Repeat this COLD water and pump out several times until the suds are gone. HOT water only makes the suds worse and prevents the pump from expelling the water.
Jul 07, 2009 | Bosch Dishwashers
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Dishwasher
Hi, it sounds like there is no watewr supply to the machine. Try turning the valve closed, and then opening it again. If that doesn't work, turn off the water and disconnect the supply hose. Then, with a bucket handy, turn the water back on slightly to see if water is coming through the end of the hose to the machine. Also check the gauze inlet filter for blockage with grit.
Let me know how you get on before rating the solution!
Thanks, D.
Jul 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shv55mo3gb
Mar 22, 2008 | Bosch 24 in. SHV55M03GB Built-In...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
158 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
