SOURCE: multi-valves on hayward sand filter mixed up
Key Cover Assy needs new spider gasket. If it is a newer model the gasket is made into the key cover and it will have to be replaced
SOURCE: Leaking from the backwash port in the filter position
it is not seated all the way try turnig to different positions several times if this does not work it probably sprocket wheel under handle assembly is bad or unseated make sure pump is off when changing positions
SOURCE: water running through the backwash valve when in filter position
Open the valve and replace the "wagon wheel" looking gasket that sits below the diverter.
SOURCE: I have sp704t XL valve my cusin switch to backwash
sounds like the spider gasket has come out of place. Make sure the pump is off and remove the top of the valve and inspect the spider gasket (looks like a wagon wheel). If it's out of place, sometimes you can reinstall it with a silicone lubricant (clean thoroughly and lube). There should be some good spring tension and you may have to depress the selection handle to reinstall the valve. Hope this helps!
SOURCE: My hayward s230t sand filter is leaking out the
If you remove the top of the valve you will see a spider gasket that has pulled out of place. remove this and clean and dry throughly. Add a small amount of silicone sealer to the bottom of a new one and install in groves then replace top of valve and let sit for a couple of hours. That should fix. If not you will need to replace the top half of the valve also.
