Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing
I have a pixma ip3000 printer that use to work perfect. all of a sudden it don't want to print black. i've put in new ink, nothing is helping
  • 11 more comments
  • busy123 Nov 04, 2007
    I have a canon PIXMA ip3000 inkjet printer. Will not print black. Please help.
  • Anonymous Nov 13, 2007
    Error message with 8 flashes. Apparently waste ink absorber almost full. How do I get a new one and replace it?
  • sianelvis Nov 21, 2007
    My printer would not print black well even though I had just put a new ink in.I did the printer maintenence clean and first it printed saying that the black nozzle needed cleaning, I did that and re-printed the nozzle check and black printed fine, saying the printer would now work perfectly, however it does not print black well still when i go to print out documents.
  • Anonymous Nov 23, 2007
    saw smoke coming from print head shut it off replaced print head now it doesnt print at all
  • jgerardi Nov 23, 2007
    saw smoke coming from print head shut it off replaced print head now it doesnt print at all but light on front flashing orange siv times then green once
  • Anonymous Dec 04, 2007
    not printing
  • Anonymous Dec 08, 2007
    The black on our IP 3000 Pixma will not print clearly, or it has lines all down the page - how do we fix?
  • kalli1974 Dec 13, 2007
  • Anonymous Dec 17, 2007
    my canon
  • Anonymous Jan 07, 2008
    Having the same problem. Took all the inks out then the ink tray cleaned. There a rubber piece on the bottom that under the electric connection. I cleaned it as well still no black ink.
  • Anonymous Feb 12, 2008
    The black has just stop printing on my pixma ip3000, do you have any clue what the trouble may be?
  • lasertek Dec 19, 2012
    your printhead might be clogged. You can dissolve it by dipping the printhead in a warm water and alcohol solution for 20 seconds. If nothing happens, check one your toner cartridhes. One of them might be already low on ink or empty. Replace it. Also check your printing color preference, Choose whether you want to enable color or black only. See basic troubleshooting here.
WASTE INK TANK FULL
Posted on Jan 04, 2008
My printer wasn't printing magenta correctly. So I went in and and performed a maintenance clean print head etc and now all colours are printing as they should. If your not sure how to get there follow this - go to control panel, then printers. Right click on your printer and choose properties. There should be a maintenance tab click on this. Now choose which maintenace item you want to perform. Good Luck!
Posted on Oct 07, 2007
WASTE INK TANK FULL
    Scholar:
  • 136 Answers
Try a new tank, there are more and more people getting bad ink tanks. HOWEVER if it is a printer that has seperate heads you might have to change it.
Posted on Sep 15, 2007
SOURCE:
komguy
  • 2306 Answers
SOURCE: will not print.. cannon pixma ip3000
Ink has dried in the printhead. You need a new one, QY6-0064-000, around $50.00
Posted on Aug 19, 2009
  • 258 Answers
SOURCE: IP3000 WILL NOT PRINT BLACK
Try Start --> Control Panel --> Printer and Faxes
Right click on the printer --> slect Properties
Look for maintenance and try "clean" or "Deep Cleaning"
If you cannot find "Maintenance" look for "Tools"
Posted on Jan 13, 2009
pineworks
  • 4345 Answers
SOURCE: I cannot find what settings to make my Canon Pixma
Hi sorry cant use just for only black needs to have the 2 inks in it
Posted on Feb 18, 2010
pineworks
  • 4345 Answers
SOURCE: I refilled my canon pixma ip3000 black ink
Canon 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
pineworks
  • 4345 Answers
SOURCE: my canon pixma ip3000 will not print in black ink
Hi There
Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
Im trying to print with our Canon PIXMA IP3000 printer but it doesn't allow printing with a message box appearing "printer is offline" but the printer is perfectly fine and plugged in. Then I chec
check to make sure you have it set on the right printer by find printer... if that is okay check your ink levels and make sure they are in properly... you might also want to try restarting the printer and if none of those work you will have to try and uninstall the printer and then reinstall it....
Dec 21, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
My canon pixma ip3000 will not print in black ink
Hi;
replace the black cartridge if it's a new execute a nozzle check from the printer preference
Oct 19, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
My canon pixma ip3000 will not print in black in. It was print fine and one day the black ink came out less and less on the paper when I print. I change a new black cartridge and it still does not help and...
Print head is fubar and for the cost that Canon will hit you with for a new print head you really have no alternative - new printer is cheaper than print head and also comes with a warranty.
Aug 06, 2017 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print.. cannon pixma ip3000
Jun 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printing problem
Hey try removing the ink well and using menthylated spirit or rubbing alcohol , soak the base in it for 10 minutes then using a straw blow out the ink holes (where the cartridge slides in) if that fails or you get reults that still aint perfect, as a last resort boil the ink well for a few minutes then will clear it out..
If this fails the the problem my be in the ribbon connecting to the ink well, or in the preprocessor it self. If you can find another one like yours the owner is willing to part with maybe you can salvage these parts from it. If this is not the case and you need to purchase new components the i'd suggest you dispose of this printer and get another it just wont be worth fixing it in that event.
Jul 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000 inkjet new but garantie expired, no print in black
After one day in alcohol infusion and hot day washing i resumed my print head.
Thank you for your intervent.
Regards Tamburino
Apr 11, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
267 people viewed this question
Clive
Clive
old marine
old marine
Ekse
