Mpeg4 to dvd problems
I HAVE A DVC CAMCORDER WHICH RECORDS DIRECT TO SDHC CARD. RESULTS LOOK FINE WHEN PLAYED DIRECT TO TV. RECORDED IN MPEG4. WHEN I HAVE FINALLY MANAGED TO CONVERT MPEG4 TO MPEG2 TO BURN A DVD THE RESULTS ARE VERY JUDDERY AND NOT VERY FLUID. WHAT AM I DOING WRONG PLEASE?
  • 432 Answers
How are you converting the mpeg4 into mpeg 2 ?
Also I would suggest using handbreak website link below
http://handbrake.fr/
That or go to http://www.videohelp.com
Posted on Apr 15, 2009
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
In the select Video window I do not have the buttons or a picture
Hi and welcome to Fixyah,
Open your Instant DVD recorder and then go ahead and select Go Direct to the advance mode. ONe window showing out there. Select your Dazzle dvc device and then click on options. Now click on video input and then click VHS input. On video input choose video composite if your video cable is yellow, red,white cable. Then click okay. Make sure that your cable is direct connect to the video out put of your camcorder. If still the same thing uninstall your video device driver. Video device is located under control panel>system>hardware>sound video and games controller then right click on pinnacle video and audio device uninstall. Restart the computer.
Mar 29, 2010 | Pinnacle Dazzle DVD Recorder
My Sanyo hd1010 camera repeats format sdhc card on start up
its a fult with in the camcorder program chips only thing you can do is get it repaired or buy a new camcorder witch may work out cheeper
Oct 27, 2009 | Video Cameras
Can I use 32gb sdhc card on Panasonic hdc-sd1 camcorder
The camcorder only supports 4GB SDHC cards.
Regards
Jun 30, 2009 | Panasonic HDC-DX1 DVD Camcorder
How do I work my camcorder
What brand of DVD recorder? On my Panasonic, I use RCA cables to connect my camcorder to the yellow and white inputs on the front of the DVR. I have to press "input select" on the remote a few times until I get to L2, I think. This is a "line in" sort of setting and it directs the DVR to get its input from the RCA-style cables. Have your camcorder playing something you've recorded in its Video mode. If your TV is on the correct input (mine is called "Video 2", I think), you should see the camcorder image on your TV screen. Now, just rewind to the beginning of your camcorder tape. Insert a DVD-R disk (that's what mine takes) in your DVR. Hit Play on your camcorder and quickly press REC on the DVR remote. Let me know if this doesn't work.
Apr 03, 2009 | Canon ES400V Camcorder
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
DSC-M1 (or MPEG4) playback on TV
Hello, You spoke about burning a DVD. Have you tried connecting directly your M1's TV out (yellow jack) to your TV set? If the quality level is same in direct connection using the MS as original carrier as with the DVD then "ite missa est", otherwise there is an issue with the DVD burning like reencoding of mpeg4 into mpeg2, maybe some quality parameters to tweek in a remote menu....
Sep 15, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
