Fujitsu 18R1 Air Conditioner
Problem for Fujitsu 18R1 Air Conditioner
Will Not Heat
By tayls144 on Apr 15, 2009
I have a Fujitsu Split System Air Con - the outside unit is a AOT18RNEL and inside unit a AST18RBA-W. The outside unit appears to be running fine, the pipes are hot but there is no heat coming out of the wall unit. I have cleaned all the filters and it still will not heat the room.
Comments:
Apr 15, 2009
- Thanks for that, much appreciated. I checked and the fan outside IS running so does that suggest the compressor may NOT be working?? I am really hoping there is something I can do to rectify this before calling a professional.
Thanks again
Best Solution
posted on Apr 15, 2009
Helpful)
sailor666666
Rank: Guru  Air Conditioners  Expert
Rating: 86%, 197 votes
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Comments:
Apr 15, 2009
- What you can try before calling someone, is to change from heating to cooling and then back again. But when you change to cooling make sure you adjust the setpoint temperature to low (18c) and when you change back to heating set it back up again to 30 just to check. If you get someon to do the changing of settings indoors while you stand outside and listen to what is going on at the outdoor unit. Do not be in a hurry when changing over, it can take up to five minutes for delay timers to switch over. But when this happens you should hear a click and hissing sound as the valve changes over. If that happens and you are still not getting heating, you may just need a bit more refrigerant. ps. no the fact that the fan is running is possibly indicating that the unit is not correctly set to heating mode, check your remote settings.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fujitsu 18R1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 18R1 Air Conditioner
Do you recommend Fujitsu 18R1 Air Conditioner?
Answer
Answer
i have a blueway split a/c model aswh24b4 and would like a users manual , how do i get one?
Answer
portable air con - not cooling properly.. The air con blows out cold air but turns off reasonably... (More)
Answer
having trouble with Samsung smart inverter air system. had company over and they turned on air... (More)
Answer
need a wiring diagram for a m/n# twe036p130bo s/n #4392a3e2z
Answer
fan is LOADED with mold and mildew. Can the fan be removed for cleaning??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18R1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
