Question about Palm Z22 Handheld
My palm Z22 froze
When I turn on the power to my palm, and use the little "stick" to got to applications it will not let me. It just sits there frozen, I have rebooted numerous times from the back of the palm, and that has not help one iota. Pleas help if you can.
  • Thomas J Nov 02, 2007
    My Palm was frozen in one application. also showed "Low battery"
    I pluggted it in to my computer over night.
    When I picked it up this A,M. it still shoeed the same program locked in place. When I un-plugged it from the computer, it went dead, & I can't get any response from it.
    What do I do now?
I have the same problem. I fixed it the first time by rebooting from the back of the palm and plugging it in to charge. Not sure if it needed charged or not but it worked. I am having the same problem today though and know it doesn't need charged so not sure if this is a true fix but got me back up and running the first time.
Posted on Oct 29, 2007
SOURCE:
Palm z22 touch screen not responding touchscreen
The Z22 palm PDA is subjected to 3 points of failure. I got a used Z22 and discovered all 3 over the course of a few years. The touchscreen digitizer on the front is a plastic sheet on the top, and a glass screen on the bottom. Invisible layers of conductive paint are facing each other. Simply carrying the Z22 in your pocket, purse, briefcase, or even storing it in a drawer with pencils, staplers, rulers, etc., will, over time, deform the screen, and the damage is cumulative, so that the screen gets worse and worse. It is imperative to have a solid sheet of plastic or hard material over the screen at all times that you are not using it. Leaving the Z22 in direct hot sunlight will heat up and soften the screen, making the problem worse. Carrying the Z22 screen in your pocket on a hot day when you are sweating, will do the same. People report that the Z22 will work in a cool place like North New York, but the screen will quit, when they travel to Florida (hot). I have temporarily fixed the touchscreen by putting it in a ziplock, and sticking it in the freezer to shrink the top layer of plastic. That only worked twice. Then I use a hair dryer to heat the screen VERY hot, to shrink the screen - which worked very well, until I put it in a soft zippered camera case, which gently pushed the screen. Then I took the screen apart completely ( which no one has ever reported doing) and this worked amazingly well, -again- until I put it in a soft case that pushed the screen against the glass backing. I eventually replaced the touchscreen ($10 free shipping from China). All the information is on my tiny website at
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of Death, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
All these problems are discussed and solutions posted, with photos on my website. Also are discussions on what to do with the Z22, where to get parts, how to maintain the Z22, and how to get data off the device onto the new 64 bit WINDOWS computers...
Good luck. The Z22 was an amazing device in its day, and people report that there were a few software programs for it that have never been made since - hence, they still use it...
robindustygraves Sept 2014
Z22 PALM PILOT a75f3784-08d5-4a1b-85ae-67e479181e27.jpg b2146887-a4b6-43a4-931b-b0f3438348ac.jpg 12202c43-26c3-47df-a31f-bc94507b7482.jpg fc737f81-6cb4-492d-b006-199c695a4776.jpg
Aug 02, 2013 | Palm Z22 Handheld
Palm z22 touchscreen not responding
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of *****, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
( I am posting this answer on a few places on fixya, so that people with Z22's can find it easily ! )
Z22 PALM PILOT
0622ac5f-1a8b-4e47-b2d3-41600350d21e.jpg Z22 PALM PILOT d66589a5-9eed-4439-8a3e-5cc1944e2ab2.jpg 61ca79eb-5d24-47a7-9aea-aab6200c19b8.jpg c90ee8fa-0ef6-4f86-8024-0ebb9f0cb5c1.jpg
Aug 08, 2011 | Palm Z22 Handheld
How do I reset my palm z22 to factory settings?
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
  1. On your handheld, launch the Prefs application. Under General, select Security.
  2. If the Password box says "Unassigned," tap the box and create a password for your handheld.
  3. Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
  4. On your handheld, hold down the Power button.
  5. While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  6. While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
    887_palmlogo_progressbar.gif spacer.gif 887_poweredcircle.gif Keep holding the Power button during this screen. spacer.gif When you see this screen, you can release the Power button.
  7. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  8. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
Apr 15, 2010 | Palm Z22 Handheld
The touchscreen of my Z22 is broken
The Z22 is a bullet-proof device for securely saving your personal data, and full marks go to the team at PALM for its solid design. However, the AGE of the Z22, over the last decade, results in 3 problems - the batteries are all dying, and the delicate plastic touchscreen top layer is deteriorating - simply through AGE. When you say the touchscreen is "Broken", I would guess you mean that it does not respond to touch commands from the black plastic stylus that sits in the slot on the back, side, of the unit, when stored. I have never actually seen or heard of a screen that is physically "broken" - like the thousands of iPod, iPhone, Motorola RAZOR, and other touch screen phones that you see today, with cracks running across the broken GLASS. It "Could" happen that the glass screen under the top plastic touch layer is, actually "BROKEN", with the resulting cracks, but this is unlikely, since the trim around the screen is raised a HUGE distance, compared to today's touchscreens.
You can easily replace the screen for $9 if you wait for free shipping from CHINA, or, you can try a few tricks I learned on my Z22 over the years. I have put it in the freezer - which worked temporarily, heated it with a hair dryer - which worked temporarily, and peeled the top plastic layer off the screen- which worked temporarily. I have also replaced the screen with a new one. It is IMPERATIVE to put a hard plastic cover on the Z22 at all times- or you will eventually loose the screen again...
My Z22 page is at:
I hope this helps you to get your Z22 back up and running
have fun
good luck
robin dusty graves
Z22 PALM PILOT touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg
Dec 12, 2009 | Palm Z22 Handheld
Palm stuck on the Palm Powered Screen
try syncing it to your computer
Mar 24, 2009 | Palm Z22 Handheld
Can I get my z22 repaired?
actually palm does not want u to change the batt they want u to buy a new device from them but u can do it
first check the charger voltage thru volt meter or confirm from other ways that ur charger is working fine , i am pretty sure that ur battery is Dead and it is difficult to replace but can be done if u have little expertise becoz Palm does not want u to replace the batt they want u to buy a new one when the batt is dead but u can do it thru following procedure
First check the specs on batt by taking it iut like this
How to Replace the Battery on a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery which, in theory, can be recharged an infinite number of times. In practice, however, the lifespan of a rechargeable battery is finite. Replacing the battery yourself is possible if you have some skill with tools and a bit of patience.
Instructions
Difficulty: Moderate
Things You’ll Need:
* Star-bit screwdriver
* New z22 battery
* Palm z22
What to Do
Step1
Pull down on the back cover of your Palm Z22, and remove the cover from the device.there is a trick to it. The little translucent bezel surrounding the USB connector can be snapped out, revealing two T-5 (Torx) screws. Remove the bezel and the two screws and the other three sides will separate with some gentle prying as you have already discovered.
The best way to remove the bezel seems to be to slip a knife (or a thin fingernail) into the joint closest to the display. It's a tight fit but you don't have to separate it very far to get it to pop out.
The battery is not "user replaceable" - i.e. it is soldered in place, but you can buy one online if you're prepared to do the solder work.
Step2
Loosen and remove the screws from the Z22's casing using a star-bit screwdriver.
Step3
If there are tabs present on the circuit board, you will need to stop immediately. Consult with a technician about removing the tabs.
Step4
Find the battery. Move it out of the case so you can have better access to the power supply lead.
Step5
Pull the power supply lead from the battery. Grasp the base of the plug firmly and disconnect in one smooth motion.
Step6
Remove the old battery from the case and insert the new battery into the same position and with the same orientation.
Step7
Replace the rear cover on the Z22 and charge the new battery for at least four hours before use.
Tips & Warnings
* Use firm steady pressure to open the case. Sharp blows and delicate electronics do not mix.
* A star-bit screwdriver is not the same as a Phillips screwdriver. The star-bit has a six-flanged head which looks a little like an asterisk when viewed head-on.
* If your battery has a blue casing on it, do not attempt to change the battery.
How to Buy a Replacement Battery for a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery. This means that you can use it forever, right? Well, no, because even rechargeable batteries wear out eventually. Since Palm currently does not offer replacement batteries, you will have to track one down yourself. Here is how to buy a replacement battery for a Palm Z22.
Instructions
Difficulty: Moderately Easy
Things You’ll Need:
* Palm Z22
Step1
Write down the technical specifications of the Palm Z22 battery. The battery is 3.7 volts and delivers 950 mAH.
Step2
Shop at your favorite local retailer, electronics store or battery specialty store. Take advantage of the sales staff’s knowledge in your hunt for a battery that is compatible with the Z22. Bring your Palm Z22 to the store to be sure that the battery fits.
Step3
Search for an online retailer who carries the Z22 replacement battery. Once you have found a couple of vendors that have the goods, shop for the best deal. Remember to include shipping costs into your decision.
Step4
Get information about return policies or money-back guarantees before shelling out any money. Returns may not be an option for the Z22 replacement battery due to the specific complications involved with lithium-ion rechargeable batteries.
Tips & Warnings
* You will need a tool kit to change your battery. The screws on a Palm Z22 require a star-bit screwdriver to loosen the shell.
* Correct use of your battery charger will prolong the life of your batteries, whether the original issue or replacement.
* Be sure that your batter is compatible. You don’t want to fry the Z22 with a high-powered, incompatible battery.
Mar 16, 2009 | Palm Z22 Handheld
Palm Z22 won't sync, USB Device Not Recognized
The Z22 is very well designed to PROTECT your stored data - do NOT do a RESET, since this has nothing to do with your problem! It sounds like your USB cable is damaged- a very common problem, usually one of the 4 or 5 wires near one end of the cable or the other, breaks inside the plastic covering, and you loose connectivity. The "OLD" Style USB end that plugs into the Z22 is getting difficult to find, since it has been replaced with the smaller "MICRO" version, available everywhere (As of 2014 ! ) It is available online very inexpensively.
I have a full page of information on the Z22, and how to repair, take-apart, maintain, and connect it. It is at:
I hope that this information helps you to get your
Z22 up and running again.
good luck
robin dusty graves
Z22 PALM PILOT palm-z22-sync-usb-device-not-recognized-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg palm-z22-sync-usb-device-not-recognized-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg
Feb 22, 2009 | Palm Z22 Handheld
Uninstalling program from the computer?
  1. Go to Applications 650_app.gif (info).
  2. Open the Menus 650_menu.gif (info).
  3. From the App menu choose Delete.
  4. Tap the name of the application you would like to delete.
  5. Tap on the Delete button. Tap on the Yes button to confirm that you wish to delete the chosen application.
Delete programs from your Z22 by using your Z22 and not your computer
Jun 05, 2008 | Palm Z22 Handheld
Uninstall software from Palm z22, clean memory
Hit the menu button on the left, below the home button, and select the "Delete..." option. From there you can choose programs to delete. Just tried it on my wifes new z22 and it works.
Feb 13, 2008 | Palm Z22 Handheld
Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
Jan 14, 2008 | Palm Z22 Handheld
Palm Z22 Handheld Logo
138 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
