Question about Tools & Hardware - Others
Nailgun firing pin not connecting with nail
Nail gun firing pin only connects with nails 25% of the time
  • David Ford
    David Ford May 11, 2010
    What is the brand and model number, you could have an issue with the piston o ring not retracting fully, Please let me know
  • Corey McConnell
    Corey McConnell May 11, 2010
    Are you using the proper guage nail and the type that the gun manufacturer recomends?
  • 313 Answers
  • you need to make sure the guns is clean and oiled
  • make sure you are using the right kind of nails
  • some perfer the ones connected my wire and some the ones connected my paper.
Not knowing what kind of gun you have that is the best I can do..
Posted on Sep 08, 2009
With 90 # air and PC nails. When I pull the trigger nothing happens. No air noise, no nailing, no movement - just dead. It's been oiled every use.
Most likely stuck trigger valve. Easy to check. Remove nails, remove trigger to expose the firing pin of trigger valve. Connect air and very quickly depress the firing pin all the way in. If the gun fires , adjust the safety to depress the trigger valve completely. If the gun does not fire, replace firing valve, or remove and check /lube o-rings in valve. Good luck
Jul 11, 2015 | Air Tools & Compressors
I pull the trigger and you get a air sound but no firing of nails . You get air release from top of gun
Could be just a lack of lubrication in the headvalve /orings or the safety foot is not pushing in the trigger pin all the way. Easy to check. Remove the head and pull out the head-valve. Apply plenty of white grease or silicone paste to the orings and the surface where the orings make contact. Install the head and test. If the gun fires then you are done. If the gun does not fire, make sure that the safety foot is depressing the trigger valve all the way in when attempting to nail. Simple test is to remove the trigger exposing the firing pin. With nails removed and air connected, with quick motion depress the firing pin all the way in. If the gun fires make adjustments to safety foot. If the gun still does not fire (with headvalve lubed) replace the firing valve core part # ca0108. Good luck
Mar 05, 2015 | Senco & Frame Pro 601 Framing Nailer
MY NAILGUN QUIT FIRING NAILS. I LOADED UP TWICE AND USED NAILS BUT AFTER LOADING THE 3RD SET OF NAILS MY NAILGUN WON'T FIRE THEM INTO WOOD. WHAT I HEAR IS JUST A SMALL AMOUNT OF AIR FROM AROUND THE...
Sounds like you may have a nail jam. You didn't specify what type of nailer you have - most finish guns have a latch to open the nose & clear a jam - if it is a framer most of the time it requires a long punch and a hammer to push the driver back in past the jam to clear it.
Let me know if this does not fix your issue.
Nov 05, 2014 | Air Tools & Compressors
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
Can the carriage on a dewalt dc618 nailgun be adjusted
The only adjustment on nail guns is for the nail drive depth, the magazine is hard mounted to the nose piece. If you are having problems with the nail clips feeding, first make sure the entire feed path is clear of any nails, parts of nails or other foreign things. Then make sure the nails you are using are fully compatable with your nailgun. Your gun needs 16 guage nails set at a 20-degree angle no shorted than 1 1/4" and no longer than 2 1/2" long. Any deviation from those requirements will only give you a headache worse than what you have now.
Feb 24, 2012 | Tools & Hardware - Others
Nail gun- double feed
Nail guns either have a switch or a seperate trigger assembly for two options - automatic, or 'bump' fire, and sequential fire. Sequential firing may be best for you since the nose must be fully depressed and the trigger pulled for each nail.
If you're stuck with bump firing, practice your technique. Double fires often occur when the workpiece bounces back into the nose of the gun; learn to 'bounce' the gun off the material to avoid this second contact.
If you're getting double fires in sequential mode, the problem could be more serious. I keep a can of aerosol silicone lubricant on hand to clean and lubricate the feed mechanism and magazine. Make sure your tool is clean and lubricated before each use, including the 3-5 drops on the air coupling.
Check that your air pressure is not set too high. Overdriving nails reduces their effectiveness and can cause tool malfunction.
This problem could also be caused by worn out O-rings or other parts within the tool. If you're not comfortable servicing the tool yourself, take it in for repair/maintenance work.
Another important thing to remember: With tools like this, you get what you pay for. A cheap nailgun will never function as well as a quality nailgun.
Oct 14, 2009 | Tools & Hardware - Others
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Jammed makita an923 nail gun
On most all nailguns when the trigger is activated air pressure is released from the headvalve causing the headvalve to open and fire the piston. If air leaks through the headvalve orings or through the headgasket port to headvalve, it will not fire. Try applying light grease to headvalve orings and make sure that headgasket is sealing around vent hole. If it fires then replace orings in headvalve for long term repair. Secondary problem is worn safety parts and trigger or trigger pin. If these parts are worn the trigger will not push the trigger valve pin all the way in when you bump fire the gun. With air supply disconnected, apply pressure to safety while depressing the trigger and check thet the pin is moving all the way into the trigger valve. Adjust or replace as necessary. Enjoy
Sep 13, 2008 | Air Tools & Compressors
Tools & Hardware - Others Logo
186 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
