Question about Lexmark X5150 All-In-One InkJet Printer
No. red question mark shows. then printer says close cover? I does look though o.k. to me.
    Genius:
  • 2,035 Answers
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Good luck...
Posted on Apr 15, 2009
The following is diplayed on the printer. "Ink system has failed,. Sytem cannot print. Error oxc18a0201. Turn off to prevent damage." Printer is a HP Photosmart C8180 All-in-one.
Hi, You can use this link to solve printer problem.
h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&tmp_track_link=ot_recdoc/c01130468/en_us/c00551397/loc:1&lc=en&dlc=en&cc=us&product=3204788
Hope it helps.
Nov 01, 2010 | Office Equipment & Supplies
Canon MP!!0 shows "COVER OPEN" and red light alarm blinks. ¿How to fix it?
Make sure that the top of the printer that you lift to change the ink catridges is correctly closed.
Mar 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
When , I scan using the top loader, a red line appears
I would say to clean the glass where the scanner bulb is parked. Just lift up the cover and clean the glass. if you look close you could see a red mark on the glass. Steven
Feb 04, 2010 | HP LaserJet CM1312 All-In-One Printer
Shows paper stuck at screen and doesnt have
Have you tried pulling out the whole imaging unit?
Open the top cover and front cover to remove it.
Jan 20, 2010 | Copystar CS-1500 Copier
My hp printer 960 c ligth keep blinking red
One or both ink cartridge is failed.First remove the cartridges and clean the contacts on the carriage unit using piece of cotton and some alcohol.If problem persist open the cover and look where the carriage unit stops.There is two marks on the left side where the carriage stops.On the carriage there is a yellow arrow.If this arrow show left mark the color cartridge ia failed and need to be replaced.If the arrow show right mark replace the black cartridge.If you replace both cartridges and problem still persist carriage unit or logic board assembly is failed and your printer need service.
Nov 26, 2009 | HP DeskJet 960c InkJet Printer
Screen shows error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Sep 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Replace Panel in Xerox 8550 Color Printer - Close Exit Cover
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
May 14, 2009 | Xerox Phaser 8550DP Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Cannot print
toner cartridge remove than close cover if again that noise its means that heater unit is jammed due to over heating. If printer initialize normally its mean that your toner is jammed.
Jun 24, 2008 | Samsung ML2251N Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
