Not working Minolta cspro Ep3050 showing code 0400and not ready for copy
  • 469 Answers
C0400, Exposure lamp failes to turn on. The lamp under the exposure glass is burnt out or the thermal fuse for the lamp has blown. Ohm out the lamp and fuse, replace as needed.
Posted on Apr 15, 2009
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Copier malfunction
Have you just added a new toner? If so try this first.... Turn the power off and carefully remove the toner bottle you just put in.. Close the front door and turn the power back on and let the copier warm up to ready. Make one or two copies and open the front door and reinstall the toner bottle again... That should take care of the problem.... If it dose not work you probly have more of a major problem with the hopper unit..
Jun 18, 2009 | Office Equipment & Supplies
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
Error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Jan 24, 2009 | Office Equipment & Supplies
Minolta CSPRO EP 3050 turning it On appears display Code: C0200
A C0200 is a problem with one of the coronas - could be the charge, transfer, or separator.
First try resetting the code by opening and closing the main front door with the machine powered up and the error code showing. This should make the code go away.
It may or may not come back. If it does, clean the coronas.
It is necessary to remove the drum assembly in order to access the charge corona.
The EP3050 originally came with a self-replacing charge corona. It actually had a small spool of corona wire in the charge corona assembly, along with a small motor that advanced the wire every few thousand copies. This was prone to malfunctions, and there was a retrofit kit which replaced the whole thing with a conventional wire.
If you still have the code, and have no idea what I'm talking about, then it is probably time to call a technician. :-)
You will need to call an independent, as Konica Minolta no longer supports this model.
Nov 12, 2008 | Minolta EP1030/1030F CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
147 people viewed this question
k24674
jasbo
jasbo
