Question about Canon XM1 Mini DV Digital Camcorder
Banding on used tapes
I've got a Canon XM1 and recently it's started banding on used tapes. I read that it might be due to having used Sony tapes on non Sony product so I've cleaned my heads to remove the Sony lubricant and got new non Sony tapes. Unfortunately this didn't solve the problem in my case as it happens on non Sony tapes too. I haven't yet tried using striped used tapes. Do I need the have the heads serviced?
  • scorpigirl Apr 15, 2009
    Sorry but I've been using TDK for ages, same problem and I've cleaned the heads 3 times. Also the problem is obvious in on camera replay BEFORE I transfer it to PC. This problem has only started in the past few months and I've never had any problem with transfer to PC of good footage. I'll try the camera out on a pre striped used tape sometime this week and post the outcome.
    Regards
    Scorpigirl
    Brigadier General:
  • 3,917 Answers
Hi ,
Have you tried TDK tapes as they work perfectly fine and have received good feedback.
There are only a few companies that make MiniDV tape (other just relabel it),
all brand-name tape is good,
but some batches of tape are better than others,
a camcorder may show a slight preference for certain brands (mainly due to specifics of the record current setup, but this is not an assured thing from one camcorder to the next),
the tape lubricant incompatibility issue between Sony and Panasonic was resolved in the 1990s,
however cleaning heads when changing brands is still a good idea for other reasons (involving mechanical properties of the tape) ,
higher price tape usually is subject to better quality control so it should have fewer drip-outs but that is not always assured,
drop outs tend to be higher in the first and last minute or so of a tape,
avoid using LP speed if you can,
some capture problems will rest with the PC, not the camcorder,
it is tape, a physical product subject to manufacturing variations and tollerances, so you will eventually encounter a tape with some defects, and
if YOU find a brand/model of tape YOU like, feel free to stick with it, but do not expect others to like it as much as you do.
Lastly A good cleaning might help.
Thanks
Posted on Apr 15, 2009
  • e-Guru
    e-Guru Apr 15, 2009
    No Problem.
    Thanks for your time and patience.
Video banding
Well this is a case of the good ole Sound/Picture heads being dirty, the reason you are seeing old recordings and not good new one's is due to the heads not making good contact with the heads, please simply buy a new 8mm tape cleaner, place in camera and press play till 30 seconds have gone okay?
Jun 06, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My heads on the xm1 seem to be dirty, ive used a sony cleaning tape, it only makes a difference for an hr or two taping, any sugestions
Firstly, I must explain how the MiniDV system works:
Although this may sound illogical, MiniDV camcorder heads do actually use a type of lubrication cassette system and there are 2 types:
- DRY lubrication (Canon, Panasonic, JVC etc)
- WET lubrication (Sony)
Now, if you haven't noticed already from the above 2 types, you are in fact using the WRONG type of cassette on your camcorder.
Although Sony cassettes are often readily available (and often perceived to be the best quality), by using Sony cassettes on a Canon camcorder (or Pana, JVC for that matter), you are in fact causing premature wear on the heads. So, the condition you are describing as 'dirty' heads, is in fact caused by the use of the wrong (wet type) cassettes on your DRY type camcorder.
Using "WET" type cassettes on a DRY system camcorder, can often leave residue on your heads, or worse....cause wear. The same principle applies to Sony camcorders - use only Sony 'WET' type cassettes, not Dry cassettes.
This also applies when using HEAD CLEANER cassettes - as indicated, you have used a Sony Head Cleaner cassette (this is a WET type cassette), when in fact, you should be using a DRY HEAD CLEANER cassette (Pana, Canon etc).
CAUTION: when using a head cleaner cassette, only playback the cassette for no more than 6 sec's at a time (anymore will damage the heads).
Summary:
For your Canon camcorder, use only DRY MiniDV cassettes (Pana offer cassettes from Studio, Professional to Master Quality), including DRY Head Cleaner cassette. This should improve the playback quality from your camcorder.
Mar 25, 2010 | Canon XM1 Mini DV Digital Camcorder
Canon i960 printer banding on photos. How can I eliminate this? I have cleaned the print head, re aligned the print nozzle. Now what?
The FAQS for your printer suggest for your problem (banded or strewaked prints) you perform this actions:
  • Perform a manual print alignment
  • Perform a deep print head cleaning
  • Check if all orange tape was removed from print ink tank(s)
  • Select correct Media Type Settings for the paper you are using
  • Change the print quality settings.
If you need guidance on how to perform any of these actions, go to the support page of your printer:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=103&modelid=9388
and in the "Please enter your question..." textbox type "banded printing".
Aug 16, 2009 | Office Equipment & Supplies
Solids banding on Canon Imagerunner (c2880).
This Copier has had problems like this since it's introduction. Canon making a slight lemon is a rarety. If you want a copier that is 50x more reliable I qould suggest the Canon Imagerunner 3320N, This copier I deam as "Bullet-Proof" and will serve your copying needs for a good Ten Years! You can visit us at www,copier1.com or call us at
888-866-2679
Sincerely,
Gary Fischer
Aug 11, 2009 | Canon IMAGERUNNER 3530 Copier
Image extremely overexposed and has horizontal banding
CCD failure !
but u are lucky canon is repairing it free of cost just see the link just call them they tell u how to send ur camera dont worry if u are not on list just call them
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Mar 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Colors not regestered on belt
when the belt was replaced were all the rollers that the belt is driven by thouroghly cleaned ??
Jan 13, 2009 | Canon imageRUNNER C5180 Color Copier
Toner banding down the sheets
Need more info.... Is it pitch line accross the page the whole page or banding on the front or back side of the copies or is it black streaks down the page?
Sep 09, 2008 | Canon imageRUNNER 8500 Copier
Horizontal banding showing when I view either via camera or screen
Did you try cleaning the heads? I got a cleaning tape and the problem was solved.
Jul 13, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
"Banding" on Prints
Do a thorough manual cleaning of printerheads (where the cartridges sit). Many printers are notorious for clogged nozzles and the ink dries on he prinheads until it becomes a bandind issue or ladders appear, smudges too. Use a proper cleaning solution and cotton buds, until most colour is gone off cotton buds. Reinsert cartridges and try again.
Aug 25, 2007 | Canon i9900 InkJet Photo Printer
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon XM1 Mini DV Digital Camcorder Logo
81 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
