Question about Sony Playstation 3 (PS3) Console
Connecting to the Internet
I'm having problems connecting my Ps3 to the net. Im using a NTL cable modem with an Ethernet connection but when i try to set the ps3 up to connect it just keeps saying "cannot obtain IP address" Ive even typed the IP address in manually but still nothing. Is it the modem that's the problem or a problem with the ps3 or just me Any help would be greatly appreciated
  • Wilson-ps3 May 11, 2010
    hey there.
    not really having any knowledge on computers, whats the easiest way to connect my ps3 (which is in my room) downstairs to the wireless internet?
    thanks.
    Scholar:
  • 136 Answers
Turn off the PS3, unplug the power to the cable modem, let them sit 5 mins. Plug in the power to the cable modem ONLY, wait for all lights to be on steady except for the activity light Then turn on the PS3 and check the network IP addy.
Posted on Sep 15, 2007
SOURCE:
How do I hook my ps3 to the internet using a eithernet cable.?
http://boardsus.playstation.com/playstat...
That website has a great guide on how to setup your ps3 for internet connection.
This is what you need to hook up to the net for your PS3
1.You need a MODEM which is the "box thing" that connects to your pc.
1. You need a ROUTER which connects to your MODEM and in to your PC. The router allows for both the PC and the PS3 to use the internet at teh same time. Unplug the wire that goes into your PC and plug into your ROUTER so that the modem is connected to the router not the PC
3. You need to connect your PS3 to the router with an ethernet cable and your PC to the router with an ethernet cable
4. Go to that web site and follow the instruction on how to set up and account on your PS3 and get going online and have fun!! Good luck!
Mar 30, 2011 | Sony PlayStation 3 40GB System
Hi Im Trying To Connect My sony ps3 slim to the internet through my laptop (Vista) with an ethernet cable. im connecting to the internet using a usb dongle. I have no broadband hardline. Ive Made a...
you need to bridge, yes
the other thing you need to do, is right click on the internet connection and say "Allow other computers to connect to the internet via this connection"
this should allow the ps3 to grab an IP address via DHCP
Mar 21, 2011 | Sony Video Game Consoles & Games
I have connected my PS3 to my computer using an ethernet cable, but it keeps saying its not plugged in on the screen.
if you're trying to have internet connection on your ps3, you're not supposed to connect it to your computer, you need to connect it to your internet modem using either ethernet cable or wireless. hope it helps.
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my ps3 to the internet if i dont have wifi?
Your PS3 supports both wired and wireless. Heres how I have mine set up, Ive been running wired since day 1. 1st- hook your ps3 up to your modem or router with an ethernet cable. {im assuming ps3 is plugged into the tv, if not hook it up}
2- go in to your network setting on ps3.. If you start at the far left go over click and all the way down. You will see network settings. click on it and go down to the 3rd option there.. Internet connection settings. You will get a pop up that says your ps3 will be disconnected from the internet if you proceed, just hit ok. It usually automatically detects if you have the ethernet cable plugged in but just in case it doesnt go ahead and select wired. after that, just select auto for everything else. You will go through about 5 questions and it will be ready to do an internet connection test. All should be well.
If that doesnt work, make sure all the cables are plugged in and try again.If you are able to connect to the internet after that but get booted off, go back into network settings again and disable the media server. Hope that helps.. Happy Gaming
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
Ethernet port
two ports will be available on the CPU, normally 1 port for the phone cable and the other to modem, please connect to one of these ports and see.
Feb 07, 2008 | Computers & Internet
Trying to get internet connection on my ps3
I once had the same problem. What i did is that i booted the modem and the Ps3 (turned both off) and then turned them on. Then i went to the internet settings on the Ps3 and tried the internet connection check and it worked! I hope you have some help of this.
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 to internet
Difficult to explain but i'll try:
You got 2 options.
1. Buy a router and connect the modem to the router wan port and find a manual how to set it up. Then through your router you can connect (a lot of) pc's, laptops or ps3.
2. Buy an extra network card and a crosslink network cable cat5e. Use software like gatekeeper to connect both to internet.
maybe the second option is the best because sometimes isp providers register you mac adress(unique adress of your network device). It's not the fastest solution.
The first is the most professional but require some knowledge of routers, ppoa, pptp, fixed ip, Wan ip, and lan ip.
I did the second option a lot with speedtouch modems and draytek routers.
Good luck, let me know if you need more assistence.
Dec 29, 2007 | Computers & Internet
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Internet connection
Sony Playstation 3 (PS3) Console Logo
144 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
