Question about RCA Lyra RD2315 MP3 Player
Display says no files
When I turn on my player it says NO FILES on the display. When I go to the MENU: ABOUT it says Version 1.67 Free 3 mb total 476. When I plug it into computer the files show up in explore but then computer freezes up when I try to add files or shut it down. I scanned it with AVG and scan came out no viruses.
  • VVickedKitty Sep 14, 2007
    Sorry posted under wrong player. Mine is a Thompson E Music
  • Mushy23 Jan 07, 2008
    I am having the same problem!
Free up some memory for the system to work - the player requires 20 - 30 megs of memory to store info (ie indexes files). You are pushing the limit to the edge, if you want to add more music use the external memory card feature but don't exceed the song and folder limit for your firmware limit.
I have the RD2317 1G internal + 1G external - 500 songs; I thought to add a 2G but why; it would hit the song limit of 520.
Warning record feature does not work on cards over 512M consistently - crashes the player - most likely power consumption issue with external card.
Posted on Jan 16, 2008
How do i put videos on my gogear vibe mp3
You can transfer audio and video files using a software provided by phillips called Songbird by the following steps:
(Attached pictures are examples only)
1. Click "File" in the toolbar and select "Import Media..."
2. Choose the folder that stored your media files
3. Select the media files that you want to transfer and then Right Click to display a drop list
(You can press and hold the Ctrl button on the keyboard to select more than one file)
4. Select "Add to Device" and select "(Your player model)"
file if you do not have phillips songbird software. You can get it by clicking here to follow a link on the bottom right hand side you will see it say "Philips Songbird SA2VBE08S/17 version 1.7.2.1667_408 (70.39 MB) " click on the blue highlighted link and you can download the songbird software to transfer all of your movies and audio.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great
day.
Aug 19, 2010 | Philips GOGEAR SA6045 MP3 Player
My phone is deleting my text messsages and my calls I have made. When I go to check if my message sent, it says there is nothing in my inbox or outbox. How does my phone delete my stuff without me doing...
Cause 1 A number of large applications are installed on the BlackBerry smartphone. Resolution To resolve this issue, complete the following steps: Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space. Determine the application space that is available on the BlackBerry smartphone by completing the following steps: Connect the BlackBerry smartphone to the computer. Open the BlackBerry® Desktop Manager. Double-click Application Loader. At the Device Application Selection screen, under the application selection window, note the total application space. Note: Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes. Remove applications that are not required. For example, remove additional language packs and themes. Cause 2 A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager. Resolution To resolve this issue, complete the following steps: On the BlackBerry smartphone, click Options > Status. Display the menu, and select Database Sizes. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card. Cause 3 Media settings may contribute to low memory capacity. Resolution Modify the Device Memory Limit settings by completing the following steps: On the BlackBerry smartphone, click Media. Select a media application. Display the menu, and click Options. Set the Device Memory Limit to the lowest setting field. Display the menu, and click Save. Note: Some BlackBerry smartphones have integrated cameras without a media card. As a result, some features have been added to handle picture storage on the BlackBerry smartphone, including the following: · Reserved Pictures Memory: In BlackBerry Device Software 4.2.0, the default value setting is 10 MB. In BlackBerry Device Software 4.2.1 - 4.7, the default value setting has been reduced to 2 MB. This setting reserves memory for pictures that the BlackBerry smartphone might take, and reduce the File Free amount that is displayed in the BlackBerry smartphone. This makes sure that the BlackBerry smartphone has memory available for pictures that are taken when a media card is not inserted in the BlackBerry smartphone. · Device Memory Limit: The default value setting is 20 MB. This prevents the BlackBerry smartphone from storing more than the specified amount of memory use. Cause 4 An application has expanded beyond intended memory boundaries. Resolution Note: In the Java® operating environment, applications increase and reduce memory usage when the applications launch, run required processes, and close processes. An application may use more memory than it is intended to use. Please make note of the values outlined in the following steps: On the Home screen of the BlackBerry smartphone, click Options. Click Status and note the values listed for File Free and File Total. Divide each of these two values by 1024, so that they are measured in kilobytes (KB). Record the new values, and name them as Displayed File Free and Displayed File Total. Display the menu, and click Database Sizes. Record the value shown in the Total Size field at the top of the screen. Open BlackBerry Desktop Manager, then open the application loader tool. Click Next on the Welcome screen. Connect the BlackBerry smartphone to the computer and allow the application loader tool to detect it. You might be prompted to type a password. Click Next on the Device Application Selection screen. Verify that the List additional applications that are installed on the connected device check box is selected. Record the value for the Total application space, located at the bottom of the window. Calculate the Reserved Pictures Memory for BlackBerry smartphones that have integrated cameras. If a camera is not integrated, proceed to step 12. On the BlackBerry smartphone, open the Media application. Display the menu, and click Options. Note the Reserved Pictures Memory value and multiply that value by 1024. Record the value. For example, 2 MB * 1024 = 2048. To calculate the Total Amount of Memory In Usage, add the values for Total Application Space, Total Size, and Reserved Pictures Memory (if applicable). To get the Calculated File Free value, subtract the value for Total Amount of Memory In Usage from the Total Flash Memory supported by the BlackBerry smartphone.
Oct 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
Problems uploading music
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
Oct 01, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk 512 MB MP3 player - Display not working
I don't know, but ur probably gonna have to send that one in.
Good luck
Dec 19, 2007 | SanDisk Sansa e250 MP3 Player
"formatting problem"
I had a similar problem, I could upload songs, but they wouldn't play and I couldn't delete them. turned out it was cause I didn't have WMP10 installed on my PC, had an older version. the user manual states it only works with WMP10, and after I installed it (just search for windows media player 10 on the microsoft website) I was able to use the synch function in WMP10 and all the songs are playable (I'm listening to an album as I type :D)
Dec 04, 2006 | SanDisk Sansa c150 MP3 Player
What is the procedure for sending pictures over the Internet in FinePixViewer?
To send a FinePixViewer image file in an e-mail message as an attachment, Microsoft Outlook Express or Microsoft Outlook 2000 e-mail software is required. 1. In the "My Computer" window on your PC, select "Internet Options" in "Control Panel" and click "Programs". 2. Check that "Outlook Express" or Outlook" 2000" is displayed in the "E-mail" field. Attaching an image file to an e-mail message 1. Launch FinePix Viewer. 2. Select the folder containing the image file in the folder tree display area on the left. Thumbnails of the images in the folder appear on the right. "Outlook Express" or "Outlook 2000" is displayed in the "E-mail" field. 3. Click the thumbnail for the image file to be attached to the e-mail. To attach multiple files, hold down the [Ctrl] key on the keyboard and click the images to select them. To deselect an image file, click the image again. 4. With the thumbnail for the image file to be attached still selected, select "Mail sending" in the "File" menu. Your e-mail software starts up and the image file is attached to a message. Fill in the destination address, title and the message body, and then use the usual procedure to send the message. * images files sent using FinePixViewer can be no larger than 1 MB and no more than 10 files in total. If the total file size is greater than 1 MB, a warning message appears when you click [Mail sending]. If the files are too large, decrease the number of files until the warning message no longer appears. Note also that you should not exit FinePixViewer until mail transmission is completed, otherwise it will not be possible to send the e-mail message with the attached image file. * Some service providers place limits on the sizes of files that can be attached to an e-mail message. The transmission of large image files can also take a considerable time. Select "Mail Transmission Settings" from the "Settings" menu in FinePixViewer and resize the attached image files so that they are no larger than necessary.
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Open Questions:
RCA Lyra RD2315 MP3 Player Logo
116 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
