SOURCE: Nissan 2007 Frontier tire pressure monitoring system
You need to set all the pressures to 35 psi. first then drive for approx.1/4 mile. If this doesn't work to reset the light (keep in mind the code itself will still be stored even though the light goes off) you will need to take it to your Nissan Dealer to have it scanned as there may be a malfunction with the sensor. If faulty and you are under 36k miles then it should be covered under your factory warranty. Hope this helps.
SOURCE: Release the spare tire?
The spare tyre is on a cradle under the rear of the car. the long crank handle is clipped onto the underside of carpeted boot floor board. The crank handle goes into the hole just above the bumper in the centre of the rear bumper, then wind down the chain and support to release the spare wheel.
SOURCE: spare tire won't release.
This is the worst GM engineering i have ever seen !!!! The secondary locking mech. rust itself in the locked position on will NOT allow the tire to lower. After lowering the tire down approx. 2-4" the saftey lock is still engaged. I was able to reach above the tire and remove the bolt holding the hoist in place. {15 mm wrench}. Keep a floor jack under the tire to support it and as not to fall on your head. After removing the bolt the hoist is hooked on the frame member and must be lifted off to remove. Once you get it on the garage floor it is possible to disengage the locking mech. with a few tools and a big hammer. Good luck This should be a Recall
