Question about Refrigerators
Dometic RM2607 We have a dometic RM2607 fridge/freezer in our motorhome and the fridge works ok but the freezer is temperamental. If you put it on auto/gas sometimes it will freeze and then other times is goes on on or the other and the check light goes on. Then other times it goes off completely. Can you help?
  • 400 Answers
It sounds like the thermocouple is either faulty or incorrectly installed. In other words the sensor bulb may be very slightly to far away from the flame to get sufficient temperature to keep the gas flowing. This is a safety device to cut off gas supply should the flame blow out. But if you are parked at a bit of an angle, the flame will also angle away from the sensor, causing it to shut off gas supply. With regards the freezer being temperamental, this is a strange one, because on this model of fridge/freezer, the actual cooling starts from the freezer coil and ends in the fridge. Try to check the thermocouple first. Also be sure there is nothing obstructing the flame.
Posted on Apr 15, 2009
Fridge not working on gas at night
You may need to put a heating blanket on the LP tank, the temperature determines the amount of pressure on the tank and when the temp drops you lose propane pressure thus no ignition and a lockout alarm.
Apr 21, 2014 | Refrigerators
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Freezer works but not the refrigerator on rm2607
move temp sensor lower or let hang if ok then replace
Aug 02, 2013 | Dometic RM2652 Refrigerator
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Dometic RM2607 Sitting for 6 years now has cooling issue?
you can turn it upside down for 2days and try it again
May 15, 2009 | Refrigerators
Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Jan 11, 2009 | Dometic RM2852 Refrigerator
Refrigerators Logo
316 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
