Question about Panasonic DVD-S35 DVD Player
H07? my dvd player stoped working. after putting in a disc it read H07 then shuts off.
  • 82 Answers
Replace Spindle motor.
Posted on Dec 09, 2007
SOURCE:
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
H07 code appears on the read out
hi..the reason to this problem is the motor.It may
be either spindle motor problem or the motor is not
spinning up.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Panasonic DVD-RV32 DVD Player
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
H07 on panasonic
hey I just messed around with mine it was showing that code H07 like the others its kinds the same except it holds 4 more disc, I took the top off then I took the thing that holds cd still off!, there should be a brass thing I think thats for the ground, so I ended up putting some synthetic oil on the rails silver poles that the laser slides on, and where the disc sits on that black circle under it, you can see the motor it has a white thing on the motores pole so I just put a few drops on there then spinds it put some more on hoping it works its way DOWN INTO THE MOTOR thats the H07 not spining fast enough!! I put a disk in while everything was apart and its playing right now, the oil I desided to use was the stuff I use for my paintball gun lol! its really thin and slippory and im sure it will last for awhile!.... going to add more after 15 minutes of playing just to make sure its really lubed! hope this helps!!!!
Jan 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
Dvd
Replace spindle motor.
Sep 14, 2007 | Panasonic DVD-S35 DVD Player
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Panasonic DVD-S35 DVD Player Logo
158 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
