Samtron 76df 17 in.CRT Conventional Monitor
Problem for Samtron 76df 17 in.CRT Conventional Monitor
Monitor color has been changed to yellowish.
By sminju on Sep 14, 2007
I am using samtron 56V monitor for past three years without any probs, but now suddenly its display color has been changed to yellowish. It becomes normal if i hit the top of the monitor.can i able to rectify the problem.
Same Problem
May 09, 2009
-   My computer was coming and going that color but now it is permanent! How do i fix this??-   j-jaquith
Oct 09, 2008
-   my 17'' computer CRT Monitor has turned into yellowish color-   Guest
Apr 18, 2008
-   same problem-   essel
Best Solution
posted on Sep 19, 2008
Helpful)
ProfSweetlin
Rank: Guide
Rating: 84%, 9 votes
There are three Cathod Ray guns responsible for the millions of
colors.All colors are produced by mixing the three basic colors namely
Red Green and Blue (RGB) at suitable proportion. If any one of the
three guns fail firing then we get improper colors.
Try
(1) Simply tap on the monitor and see the result.(Keep the monitor on during this trial.)
(2) Disconnect the Monitor.and Slap it at the back by keeping it on a pillow with the screen facing down - it will resolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contraction.
(3) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed) -
(4)tighten the screws at the backside of the CPU
Best of luck
ProfSweetlin
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Sep 14, 2007
Helpful)
PcExpert
Rank: Wiz
Rating: 79%, 526 votes
Try un twsiting your signal cable if its twisted. Else your Red And Blue Signals are faulty. or the RGB\Video Board of the CRT has a problem.
Was this helpful?
Yes
No
Popular Solutions for Samtron 76df 17 in.CRT
Questions and Unsolved Problems for Samtron 76df 17 in.CRT
Do you recommend Samtron 76df 17 in.CRT Conventional Monitor?
Answer
Answer
I have a SOM-M81 and it has a blue hue on the screen my monitor is a SONY and the picture color is... (More)
Answer
Picture is appearing yellowish . When i shake the monitor slightly, momentarily it gives the... (More)
Answer
mysamtron 76E keeps having control lock or unblock in the middle of the screen and then i have had... (More)
Answer
Using Vista, I am using a notebook but I want to change to a different monitor. I have the external... (More)
Answer
widthless display and excessive height found in monitor, but the variation ok through the micro... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
