Question about Motorola Mobility RAZR V3
No signal! I dropped my phone in water the other day, and removed it within two seconds. I then immediately took the battery and sim card out. After waiting for it to dry, I put everything back together, and it worked fine. A few hours later, though, the signal disappeared! I haven't been able to make calls since. Any tips?
  • 626 Answers
There is most likely corrosion from the water, or liquid on the mother board. It needs to be professionally cleaned if you want to have some functionality back. Best of Luck.
Posted on Sep 14, 2007
I immersed it in water for few seconds
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Jul 02, 2011 | Cell Phones
I have dropped my E5 into the bath
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front of a warm fan heater for several hours then reassemblethe phone. Hopefully it will work properly but if does not work then it isfaulty and you need a new cell phone.
Jun 27, 2011 | Nokia E5 Cell Phone
Absolutley EVERYTHING still works just blank screen after dropping in water.
If you put it in water, immediately shut the phone off, pull the battery, sim card (if applicable) and put everything in a bowl of white rice for a few days. The white rice should remove the device enough so everything should be usable.
I've also heard that immediately freezing the phone works too, your choice.
Jun 11, 2011 | Cell Phones
I dropped my lg vu cu920 into the water and it just says emergency dowload, what do i do?
Take the battery out, dry the phone, battery, SIM and/or memory card with paper towels as much as possible. Take all of the pieces and wrap them in a single paper towel loosely. Drop this in a ziplock bag and fill it with baking soda, then zip it up. Let it sit for 2 - 3 days.
The worst thing to do with a phone that has been in contact with water is to run a current through it.
May 03, 2011 | LG Vu CU920 Cellular Phone
I dropped it in a toilet for no more than three seconds. I immediately removed the battery and sim card and soaked the phone and battery in rice for a few hours. The water damage sticker is white but the...
the first step is to take the battery of the phone and place both the the phone and the battery in a zip lock bag with rice and leave it for three day and then put it back together and the phone should turn on
May 18, 2010 | Cell Phones
My samsung Im pression touch screen is not always there a quick fix for this(ie. battery) or will i need to send it for repair....if it needs repair, what is the cost range?
try to do these steps, and bring your phone back to it's factory settings. make sure to remove your sim and memory card. please take a note that if your phone is under warranty, you may choose not to follow this, hence bring your phone to your nearless service center.
to make a hard reset...
1. switch off your phone
2. remove your battery
3. remove sim and memory card
4. reinsert battery and switch your phone on
5. while your touchscreen is working, type the code
*2767*3855# to set it back to its factory settings.
6. after a successful hard reset, remove battery and reinsert sim and memory card, reinsert battery and switch on and check.
7. play with your phone by doing reconfiguring it to your settings and check.
Feb 25, 2010 | Samsung SGH-A877 Impression Cell Phone
Nokia n 73 droped in water for 3 seconds
This happened to me one fine summers eve in a pool in Los Angeles, but i'll spare you those details ;)
There is indeed hope! Make sure you dont put the batter back into it for a few days, take some dry rice and immerse the phone into it, the rice will **** any of the excess moisture out from the phone. DO NOT douse it in rubbing alcohol, and do not "bake" it in an oven or in too hot of sun, this will deform the internal electronics.. Hope this helps! :)
May 30, 2009 | Nokia N73 Cellular Phone
Maybe rzr v3m; black screen after dropping phonein water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
W810i took a bath!!!!!!
is should have hardware damage since it has been expose to water. you have to send it to service center to get it fix.
Jul 22, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Motorola Mobility RAZR V3 Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
