Question about Dryers
Machine wont dry my clothes
Hi, my whirpoool machine is not blowing out hot air, the cycle is still runningto dry but clothes still coming out wet
    President:
  • 1,865 Answers
Gas or electric? Gas - Igniter unit needs replacing. Electric - Heating element needs replacing
Posted on Apr 15, 2009
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Nov 27, 2013 | Zanussi TC7114W Electric Dryer
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
My Neff drier isnt drying my washing it is hot but the
Is the fan working? this blows air across the element which in turn cools the steam into water then pumps it out via pump,Hope this is of some help
Apr 13, 2010 | Neff V4380X0 Front Load Washer / Dryer
AF Code flashes briefly; Clothes don't dry - vent clear
Remove the back of the dryer and chek the lint filter area from the lint catching filter to the exhaust tube. There is a blockage in airflow even though you feel the air at the exhaust there still insn't enough air flow to allow the proper drying of the clothes. This symptom that you gave clothes being hot but not dry the only cause for this is improper air flow
Dave
Mar 31, 2010 | Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Dryers Logo
102 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
