Question about Planar CT1904Z 19" Flat Panel LCD Monitor
Line of Discolored Pixels Down Center of Screen
Around the center of the screen, there are two vertical lines of discolored pixels - one seems to be green and white, the other purple, which isn't always visible. I tried to fix the problem by updating the driver, but Windows XP only uses a basic Plug-N-Play driver that doesn't solve the problem. Planar says "If you are running Windows XP or 2K, you can specify a digital flat panel display (and your monitor's native resolution) under standard monitor types within the display driver update wizard" but I haven't been able to find out how.
  • 293 Answers
Re: Line of Discolored Pixels Down Center of Screen
Are these lines visible in POST or boot up? if they are then your LCD is faulty.
Posted on Sep 14, 2007
0 characters
3 Points
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computer Monitors
Milk white screen.
Try updating the display drivers ... Hope it turns goos after the update ...
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Have a purple line that runs down the screen on my s27a950d monitor. is there a solution to this?
You can use this pixel test, this test for dead pixels, but it will also help with stuck pixels,move through the colors, look at each color to see if the line remains on each color, then switch between colors as fast as you can, do this at least 5 times cycling through the colors. If this does not help I think you will have to go to the MFG website and check your warranty. If you don't have one or it's expired and you end up buying a new one, make sure you check, one of the best places around for computer parts.
Mar 27, 2013 | Samsung SyncMaster S27A950D - 3D LED...
There's a green line going down vertically on the monitor screen all the time
a resitor line has failed and you cannot fix it, once they fail thats it ,its there for good. Its same as dead pixels on a monitor, except this is a whole line of pixels, if you hit the area above the line hard it will probably go away but will come back sometime, learn to live with it or buy a new monitor.
Apr 03, 2011 | HP Pavilion F1703 17" LCD Monitor
There is bright green vertical line occurred on middle of the screen
I am afraid your computer's screen has a defect. You should apply to nearest service. If your computer is still in the guarentee period thats fine. There may be exists different guarantee conditions for LCD screens, (death pixel guarantee) and some brands give this against even 1 death pixel. You have lots of death or distorted pixels (a line). Do not lost time and apply to your vendor.
Aug 24, 2010 | HP w1907 LCD Monitor
My monitor has a yellow line running down the middle
This is a bad LCD panel. If it is still under warranty, your best bet is to have it replaced again. The only fix is to replace the actual panel and that would cost more than a new monitor.
Sep 28, 2009 | Acer H233H bmid Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computer Monitors
New Samsung PDP TV - picture problem
Unfortunately, you have to return the set.
You have a column of bad pixels. Take it back as fast as you can so you don't have to take it to a service center for repair.
Mar 22, 2008 | Gateway FPD2275W LCD Monitor
On the Screen Red pixels comes in the background
if you are see red pixels then your monitor haveing LCD Panel problume.
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Planar CT1904Z 19" Flat Panel LCD Monitor Logo
575 people viewed this question
Top Planar Computer Monitors Experts
Clive Gray
William Miller
William Miller
Joe Goldman
Joe Goldman
Are you a Planar Computer Monitor Expert? Answer questions, earn points and help others
