Question about SanDisk Sansa e260 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
Whenever I turn on the player, it shows these messages:
"Not enough space for Music DB. Please free 6MB."
"Database had to be repaired. Connect to your PC to refresh database."
When I go to my music, there's no songs. It's completely empty. Yet, when I try to connect to the PC to fix it, it shows all of the music files. Also, when I try to free some space by deleting some songs, the error message doesn't change. Please help me out.
  • 4 Answers
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Posted on Apr 16, 2009
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
How do i get into the sansa when it says not enough space for db
It happened to me after I formatted my Sansa into a NTFS file system. This is how I solved it:
1) Connect your Sansa to the PC (if the player won't turn on try hold the middle-button while you're connecting it).
2) On My computer right-click the player and choose Format (make sure it's set to FAT32).
3) Now you can turn on your player normally - when you're inside the player menu choose Settings->Format. This will re-create all the player sub folders (music, audiobooks etc).
That's it...
Hope that work for you too... ^_^'
Jan 28, 2010 | SanDisk Sansa Clip MP3 Player
Deleted all my songs, and talks about freeing 6MB?
Reset your player back to normal. Note that this will delete all files you have on your player, but it resets the player as if you just bought it. To do a safe reset, please make sure that your player is only a Sansa E250, not Sansa E250R. Here is the link that resets your player back to normal. http://forums.sandisk.com/sansa/board/message?board.id=smc&thread.id=755
If you understand it carefully, you will have no problems. I recommend you read it one by one so that your player doesn't get bricked (kind of un-repairable) because the steps you followed were wrong.
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Music DB?
You have put too many songs on the device.
It needs some free space to create the Music Database or the Artist, Album, Song information.Generally between 6 - 10 MB for each GB of music on the device is sufficient.
If it shows up in My Computer, you can manually delete some files from the MUSIC folder.
If not, you can use the following software to erase everything and start over.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 27, 2007 | SanDisk Sansa e260 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
PLEASE HELP I CAN"T LIVE WITH OUT MY SANSA
"Please free 6MB for music DB" means that there is not enough MEMORY for the MUSIC DataBase. Therefore, you cannot see the music on your device.
To resolve this, you need to delete music until your device is less than 6MB of being full.
Generally 10 to 15 songs should do the trick.
Best of Luck,
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
My sansa wouldn't work
The device needs 6MB free for each GB of music.
Delete about 10 or 15 songs and you should be all set.
Best of Luck.
Oct 30, 2007 | SanDisk Sansa e200 MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
229 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
