Zenith TV won't power on
Zenith TV model B25A24Z clicks when I press power but wont turn on. For months it would turn on but picture wouldn’t fill screen area and it would turn off almost immediately unless the room was quite warm or unless I repeatedly turned it back on after every time it shut itself off. Once it was on for a while it would stay on without a problem. Now I can hear it click when I press the power button or the remote- but it doesn’t actually come on at all. Thank You.
techman
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
SOURCE: TV won't turn on
Rix20601- how hard is it to repair the high voltage board? i'm hoping to locate a fuse somewhere, but i fear those days are long gone.
Posted on Feb 19, 2007
SOURCE: TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Posted on Jun 25, 2007
  • 1153 Answers
SOURCE: tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Posted on Dec 25, 2007
Shuttle83
  • 1139 Answers
SOURCE: tv power wont stay on
Hello All,
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 25, 2008
No audio on order from amazon prime
lg tv 32 inc model /// 32lc56-zc i have a problem with the audio can you help my please
Mar 08, 2014 | Zenith B25A24Z 25" TV
The picture freezes and the sound is lost. Until the picture returns and the sound returns,this happens every couple of seconds.
If you actually have the Zenith model TV (B25A24Z), the trouble is not in your set. This model has only an analog tuner, and what it sounds like you are describing is digital pixellation. This is what happens with a digital-to-analog converter box when it gets a weak signal, with rain fade or heavy snow on a satellite dish antenna, or when a digital cable system has some signal problems. The converter equipment locks the last complete frame (or breaks up into blocks and freezes) and the sound is muted.
You'll need to look for the cause of your trouble in whatever is feeding the TV. If you have a digital converter box for off-the-air broadcasts, make sure you have a good antenna and all the connections are tight. If you have satellite TV service or digital cable service, you might need to contact your service provider for help in troubleshooting and fixing the trouble.
Dec 19, 2010 | Zenith B25A24Z 25" TV
How do you fix a tv that wont turn on
sony MDL.KV-32FS210 Tv power light flashing,awaiting signal to come on. neither tv or cable remote wont turn on tv, manual button has no effect. I assume relay inop. Ther is no clicking as I normally hear.
Apr 05, 2010 | Zenith B25A24Z 25" TV
Can someone take a picture of the original video settings on their Zenith B25A24Z 25'' TV because my screen is all messed up and doesnt get much better when i play with settings.
If this TV is a 25"...then this is an older set. Is the picture dim and the colors dim, will the tint not correct the color scheme? Zenith picture tubes, as a rule, for this model go bad...sorry but this is true!
Dec 10, 2009 | Televison & Video
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
TV - no audio
We lost the chat communication.
check this LINK to download your schematic diagram. Make sure you get all the 7 parts before you can open it.
You will need winrar and acrobat reading 6.0 or newer to view the schematic.
Good Luck.
Mar 10, 2008 | Zenith B25A24Z 25" TV
TV - no audio
TV wirked fine for years, but when we moved it to a new house 100 miles away the sound was gone even the cable supplied picture is great. Cable company couldn't recover the sound either.
Mar 04, 2008 | Zenith B25A24Z 25" TV
Horizontal line in top screen
could be vertical output IC or capacitors located close around the IC
Nov 27, 2007 | Zenith B25A24Z 25" TV
Lost code
what make & model
Oct 12, 2007 | Zenith B25A24Z 25" TV
Zenith tv
due to shifting your yoke coil might have turned. if you are not tech person get it done by tech. good luck.
Oct 06, 2007 | Zenith B25A24Z 25" TV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
