Question about Brother HL 5250DN Laser Printer
Brother hl5250dn printer making noise during paper picking
  • nancyf296 Apr 20, 2009
    we also have the HL5250 and it also makes a lot of noisy when picking up the paper (if it picks up the paper) because sometimes it will not + it seems we can only put about 20 pcs of paper in the tray - anymore than that and it will not pickup it up.
    i almost ready to get rid of this noise maker and go back to the HP....
    any suggestions.
  • bobsedge Apr 28, 2009
    I frequently have the same problem. Sometimes, if I hold the blue plastic lever down (front RH side) it will work. But, now, nothing works.
Check the rear end of the paper tray. There is an adjustable bar for paper size that is probably not locking into place. If this moves accidently when refilling the paper tray. it may cause a rather unnerving noise. You need to adjust this bar to fit snugly with the short edge of the paper stack.
Posted on Apr 29, 2009
I've had that challenge with mine also. The noise stops once I adjust the paper tray and make sure it's locked.
Posted on Jul 12, 2010
I ran across this yesterday. tried all the solutions to no avail. the paper would
start to feed but would not go very far and very noisy. when I took the tray out to
investicate the rollers, I noticed one of the white things behind the rollers was down instead of uplike the other two. I tried to push it up into place from the front.
I ended up taking out the toner and sticking my fingers in from behind and was able to snap it back into place. after that it printed just fine and no noise.
Posted on Nov 02, 2012
5890cn manuals part and assembly
Go on free manuals sites , I have a few of them, and you can download manuals for virtually everything you have even things you get at goodwill.
Oct 04, 2014 | Brother Lower Paper Tray Feeder / Tray for...
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
Brother HL5250DN makes loud squeaking noise while printing. Sounds like crickets chirping.
This is not a problem but it can be early signs of the drum and rollers wearing out. When it does die, I suggest buying another printer.
Dec 07, 2010 | Brother HL 5250DN Laser Printer
My brother hl5250dn laser printer won't feed paper. all seems okay other than that.
Make sure the paper guide at the rear of the tray is not set too tight, it needs to be right on the mark for the size you are using. After that you can clean the rubber roller above where the paper sits with a towel damp with alcohol. If it still doesn't feed you may need a shop to check the roller drive gears and clutches.
Feb 05, 2010 | Brother HL 5250DN Laser Printer
Hi - I have a Brother HL5250DN with the paper light flashing but there is paper in the tray and now it wont print - can you help??
Is the Status light also red? This could mean other things than being out of paper. It could be a paper jam (most commonly anyway). Get a flashlight out and inspect it for jams.
Jan 13, 2010 | Brother HL 5250DN Laser Printer
Brother HL5250DN PRINTER THE DRUM LIGHT KEEPS ON
it has a drum sensor ,it was disable to work but it look like new please change ot replace drum unite not only drum total unite then solve your problem
thanks Tareq
Nov 11, 2009 | Brother HL 5250DN Laser Printer
I sprayed dust remover & now the printer won't print. the status light flashes red & the toner, drum & paper lights flashes yellow (hl5250dn)
You may have blown dust or paper shard into one of the optical sensors. These sometimes are used to sense paper position and carriage position. Try cleanig again and pay attention to these sensors.
Sep 01, 2009 | Brother Office Equipment & Supplies
Brother hl5250dn laserprinter problem due to no impression.
unistall the printer driver and reinstall it or cheak it,s ink cartrage
Aug 22, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Apr 06, 2009 | Brother HL-5250dnt Laser Printer
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
Feb 05, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
1,048 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
