When I am opening My computer THe whole system is hanged. My computer configuration is, Motherboard : M2A-VM HDMI Hard Disk : Seagate sata 500GB Ram : Kingston Hynix DDR2 2GB x 2 DVD Writer : L.G sata
When I am opening My computer THe whole system is hanged. My computer configuration is, Motherboard : M2A-VM HDMI Hard Disk : Seagate sata 500GB Ram : Kingston Hynix DDR2 2GB x 2 DVD Writer : L.G sata 22x
  • coolgoldyg Apr 15, 2009
    O/S : Windows Xp sp2
    antivirus : Bitdefender total security 2009
    Brigadier General:
  • 7,191 Answers
Maybe due to some virus/malware running in the background. Also, can u let us know the OS/ antivirus software u are using
Posted on Apr 15, 2009
  • AliTech110
    AliTech110 Apr 15, 2009
    If you have your original XP installation CD, you try & repair the installation. U will not lose any of your files and settings this way. OR you try and update your installation to SP3 by downloading SP3 update from Microsoft.
I am interested in this drive Seagate Momentus XT 500 GB. I want to know how to install this drive into my desk top computer with a 3.0 slot for the drive as it is only 2.5 inches wide.
To install a Hard Disk Drive(HDD) into your desktop, take off the side panel of your case. Locate the SATA slots on it, they should be above the available Optical drive slots.
Put it in place, depending on your case you should either have a latch which locks it in place or you will have screws. After you've done, make sure that if you have another HDD in your PC, and you will not use this HDD for System files(C:\ drive), you will have to set the new one to Slave configuration. To do this you need to take out that jumper inside of the HDD(you can use some tweezers) and, according to what's printed on your HDD, move it up or down.
When you've done that, insert the SATA power supply cables from your Power Supply(PSU). After that use the SATA interface cables which came with your HDD and plug them into your Motherboard's SATA adapters. Locations of these vary depending on the motherboard so it's always best to refer to your Motherboard's manual to check locations.
After that start your PC and open up your BIOS/CMOS. Usually you press a key such as F2/F5/Esc on bootup. Configure your Motherboard to check for new drivers. After that save and exit and it will restart your PC. You should have installed your new HDD!
Aug 20, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
I lost my mother driver software cd.Model of my mother board is M2A-VM HDMI.Please send me it.
Dear friend Go there http://support.asus.com/download/download.aspx?SLanguage=en-us
You may see top the left corner Search by model please put the model number here
your model is M2A-VM Then click the search button.. you may put your operating system then you find all for download thanks.
Mar 26, 2009 | ASUSTeK M2A-VM HDMI Desktop Board - Athlon...
M2A-VM random reboot
there is no windows xp sp3.all sp3 are made by hackers which used to hack the systems easily.so please change ur operating system and also uncheck the My computer(right click)->properties->advanced->startup and recovery,uncheck the automatically restary.
ur problem may be solved.
Jan 10, 2009 | ASUS M2A-VM (0610839149438) Motherboard
Hard drive not found
When is your hard drive not recognized?
At boot or in the BIOS?
You might haven connected your hard drive correctly or you'll need to enter bios and select an option for bios to detect your hard drives and save the new configuration.... otherwise there is a serious problem with your hard drive not functioning.
At windows XP?
You might need to enter windows ADMINISTRATIVE TOOLS in the CONTROL PANEL and click in COMPUTER MANAGEMENT in there click STORAGE/DISK MANAGEMENT you'll see all your connected hard drives, your new hard drive should be listed there, but may not have a letter assigned/partitioned or formatted. Do so and it will be recognized.
If you're trying to install windows XP?
It's probably because your PC has the new SATA interface hard drives, you need to load a special SATA driver through floppy disk during at the beginning of windows XP setup, for it to find hard drives on your pc. You need to make this floppy disk with files that are available on your motherboard CD, in there are all the instructions you need.
Jan 07, 2009 | ASUS M2A-VM (0610839149438) Motherboard
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
With dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Tia.
Mar 29, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
