I've a motorola xt925 cell phone but i cannot unlock its memory and share music from my computer because it doesnt recognize my cel in the desktop , what can I do? thanks
SOURCE: memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
SOURCE: installing the memory card in my Treo 650 cell phone
there's a card slot on top of the device - see pic attached (which shows both - SIM card and memory card slot opened). To open it press down and release dummy card, thenn pull it out and put SD card into slot (pushing it slightly deeper)
You can back up your Treo to either your PC or your SD
card. If you back up to your PC via hotsync, then there is a nice freeware which
can be installed to your Treo that is called SyncAll (all one has to do is right
before the sync, open the program and click "force all to sync"), and it will move
all the files, including preferences and such that don't normally get sync'd. If
you backup to your SD card, there are numerous programs for accomplishing this. It
is important that the number of backup-to-SD programs are limited for the Treo 650
due the NVFS file system. You can try THIS ONE for example - it's free.
SOURCE: phone can't recognize external memory card.
my phone can not recive songs on extronal memory
SOURCE: My Black Jack won't recognize memory card
common bug. Turn it off... take out the chip... wait.... turn it on... wait till you see the windows mobile screen not the samsung screen... then put it in... and when it boots up you should see everything.
make sure your card is formatted too. (they usually are)
SOURCE: Motorola W270 Memory Card problem
you need to reset memory card settings. scan your memory card with an antivirus. format it.
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your sd card drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your sd drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
