Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
F1 - E0 EEPROM communication error F1 - E1 EEPROM checksum error F1 - E2 UL A/D error F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match stored value F2 - E0 Shorted touch pad F2 - E1 Keypad cable connection error F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models) F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models) F3 - E2 Oven temperature is too high (Cook mode) F3 - E3 Oven temperature is too high (Clean mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models) F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models) F3 - E6 Drawer sensor open F3 - E7 Warming drawer sensor shorted F4 - E1 Meat probe malfunction - shorted F5 - E0 Door Switch F5 - E1 Self clean latch will not lock F5 - E2 Latch during CLEAN error F5 - E5 Self clean temperature not reached within 45 minutes. F5 - E6 Door is open, but latch is locked F5 - E7 Self clean latch will not unlock F6 - E0 Return line not connected F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure F1 ERC Board failure F2 Oven temperature is too high F3 Oven temperature sensor open F4 Oven temperature sensor shorted F5 ERC Board failure F7 Function key stuck on ERC F8 ERC Board failure F9 Oven door lock failure
If you get an error code, try first resetting the code: 1. Disconnect power for about two minutes. 2. Connect back power. 3. If code re-appears, test and eventually replace faulty part.
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper oven, if double oven) F3 - E2 Oven temperature is too high (Cook mode)
F3 is an open or shorted oven temperature sensor, you will have to replace this and it should be attached near one of the elements but you will have to pull it out through the back.
E2 is, sorry to say, a possible ERC or Electric Range Control, otherwise known as the brain behind it. But on the plus side, sometimes it gives this code intermittently when it can't process the information from a failed sensor, so you might get lucky.
