Question about Nokia 3560
Nokia 3560 Is the above phone 911 compatible..I have a motorola but need to get a new phone....the verizon website will not let me activiate nokia on line
4 Suggested Answers
  • 270 Answers
SOURCE: how do i get my h350 to operate with my nokia n70
try to pair devices in bluetooth menu then set the headset as authorized
Posted on Dec 03, 2007
  • 59 Answers
SOURCE: NOKIA N72 Network Problem
there is a network ic problem with your phone, it must have got damaged get it repaired from a local repairman.
otherwise try upgrading the phones firmware by going to nokia site and downloading a new update and then via data cable update the phone operating system.
Posted on Apr 10, 2008
  • 115 Answers
SOURCE: I have bought a bluetooth headset but I have no
Press the MFB button on the bluetooth headset for about 8 seconds until the blue and red light flash together.
Please note, after pressing MFB button for about 5 seconds, the blue light flashes. Do not release the button and keep pressing until the blue and
red light flash together, which indicates that the headset is now in paring mode.
You will then do the search from your headset. You may be prompted for a passkey, it should be 0000
For the manual to your headset go to
Posted on Apr 21, 2009
  • 34 Answers
SOURCE: Unlocking Nokia 6288
Follow the instructions given below for unlocking your Nokia 6288
Warning : Do not enter any wrong unlock codes on your Nokia 6288 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6288 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6288 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6288.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6288 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6288 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6288
Using the unlock code specified in this site you can proceed unlocking your mobile
Posted on Jul 06, 2010
0 characters
1 Points
Not working opera mini
Opera mini which you downloaded is not compatible with your Nokia cell You need to download Opera mini which is compatible with Nokia 7230
Or else
You can download Nokia OVI browser from Nokia OVI website for FREE.....! It's browsing speed is high compared to Opera mini browser
Thank you
Don't forget to rate
Jan 17, 2011 | Nokia 7230 Cell Phone
When i try turning my 5230 on it just comes up with the intial white screen that says nokia on. It wont load up my screen. Please help, thank you
Try the following suggested solutions as they may solve your problem:1. Remove any newly added hardware on your device, e.g a MicroSD device(memory card), and replace it with a component compatible to your product.2.Upgrade your phone's firmware.You can do this through the Nokia PC Suite provided with your phone.During the firmware upgrade process, ensure that your phone remains connected throughout the operation and that you have a working internet connection.
Procedure:1. Download the Nokia PC Suite from the Nokia Website at and ensure that you select the appropriate phone model2.Install the Nokia PC Suite(latest version is Nokia PC Suite 7.1 as at the time of writing this) on your computer.3.Connect the Nokia phone to your computer via USB.4.Follow the procedures at and to upgrade the phone's firmware.
I hope the above data will help.For more on tweaking your Nokia 5230 phone, follow the link beloe:
Have a good time ahead.
Dec 18, 2010 | Nokia 5230 Cell Phone
I have a Nokia 3560 phone that has a locked keypad. I don't know the unlock code or the security code. Is there a way to unlock this phone so I can use it
HELLO You can try this site
after visiting that site enter your phone's imei no. in the box given and click the GET MASTER CODE button after clicking on that button you will find a master coder for your mobile
if you dont know how to get a imei no. then open your phone's backside and remove your battery then you will find imei no.
Apr 28, 2010 | Nokia 3560
Bluetooth connectivity nokia 2630
As with most cars, only certain models of phones work with your mazda. Usually they are Motorola V3s and most blackberries and some samsungs. You should go online to and ry to find a list of supported bluetooth phones. Sorry there is no working solution to make ur phone work with your car
Mar 11, 2009 | Nokia 2630 Cellular Phone
Mobile phone
Enable the bluetooth in your mobile.If the motorola hands free kit is compatible with N95 it will be detected.Else you have to go for a nokia kit only
Sep 02, 2008 | Nokia N95 Cellular Phone
Mp3 driver motorola sliver L7c vista pro
I found these drivers for XP here:
And for Vista drivers, use this address:
Alternatively, you can download and install the USB Drivers from These drivers are often newer than the ones above, but you will need to create a user-id first. After logging in with the new user-id, search for "usb driver", or navigate directly to
After downloading and installing the Motorola Driver, you will need to run the Motorola Driver Installer program by going to "Windows->Start->Programs->Motorola Driver Installer->Motorola Driver Installer.exe".
This alternate Motorola USB Driver is required for most phone models from Verizon, Alltel, and US Cellular. Some of these models include:
Alltel V3a, Verizon K1m, Verizon Maxx Ve, Verizon L7c, Verizon W385, Verizon W755, Verizon Razr2 V9m, Verizon V750, Alltel Razr2 V9m, US Cellular Razr2 V9m, Sprint V3m, Sprint K1m. I hope this helps someone. :o)
Jul 03, 2008 | Motorola Cell Phones
If you are on Verizon wireless you can go to their website and do an esn change to a phone you have around the house then wait a few minutes for the order to process. Then after about 15 minutes change the es # back to your sLvr and dial *22899 and press send. After the phone has completed programming the lock code will be the last 4 of your cellphone # again!
Jan 10, 2008 | Motorola Mobility SLVR L7 Cellular Phone
N95 blue tooth pairing
remote sim (off)
That should be ON
Dec 14, 2007 | Nokia N95 Cellular Phone
How to connect????????
that is because your nokia 6300 mobile phone isnt compatible with motorola you need the same brandname as your mobile
Sep 23, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 3560 Logo
37 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
