Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Canon ixus 50 the camera is not switching on and the lens is open
Canon ixus 50 i switched on the camera and the battery when off with the lens kept opened, so i charged the battery and tried to switch on but it is not working,and the lens is opened
    Scholar:
  • 57 Answers
Check the battery cover closes properly, the camera will not operate at all if the switch thinks the cover is even slightly open. Try removing the card, sometimes they cause cameras to not start when they are faulty. If all else fails, the fuse is most likely blown. They are internally located just near the power switch but you are best to have a service centre replace it for you. Best of luck.
Posted on Apr 15, 2009
  • 489 Answers
If your lens is jammed, then there are a few things that you could do, but I can't endorse those methods as they can cause even worse damage to your camera. However, if you look to get it repaired, you can get it repaired for fairly cheap (certainly less than what Best Buy or Canon will tell you) Just do a Google search for Canon SD400 lens repair, there are a few options for you!
Posted on Jun 13, 2009
My canon ixus 75 has no power.
There are many ways to troubleshoot this problem.
First try to insert new batteries and then tap on the sides of the camera and turn on the camera. It will switch on if the problem is due to loose connection.
Secondly, clean the battery terminal before inserting new batteries and check through a multimeter, whether the battery terminal is receiving the power properly from the battery. If there is no power, you need to contact canon to get the element replaced. If there is power in terminal and still not switching on there is some chance that lens is stuck inside, and it is not allowing to switch on. So clean the lens and try to turn on the camera it will work fine.
If you still have the problem then it tends to be the problem of the circuit board inside the camera.
Hope this helps.
Shane
Feb 02, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
My lens for my ixus 750 is stuck open. when
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Lens error When the camera is switched on the lens does not open out and the lens cover does not open. The camera then displays a "lens error" message and suggests that the camera be restarted ten...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera lens will not open
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 12, 2008 | Canon IXUS V2 Digital Camera
Canon ixux
try newer batteries 1st see online if ther is firmware update for your cannon.com model camera try those 1st thx nick
Oct 06, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera beeps five times, doesn't work
the beeps mean the lens can't be opened or closed. maybe something stuck or it's just failed?
Aug 30, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon Ixus 5.0
abserve the whether dist particle are jamed in lence groov becuase fine dust also problamatic for it
Jan 02, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
209 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
