Question about Singer 7436 - INGENUITY
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue? More of a sewing question actually a 7470, not 7436
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Posted on Jun 10, 2009
Singer conferdence 7470 not sewing
Try a brand new needle. If that doesn't work, then the machine is most likely out of time. Search for sewing machine timing or take it for service.
Feb 13, 2017 | SINGER 7470 Sewing Machine
My singer 7470 i start to sew and clicks and bunches the cotton then the bobbin catches on the hook
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
if these suggestion don't help then the machine needs to be checked to see if it needs some type of adjustments
Mar 19, 2014 | Singer 7470 Computerized Sewing Machine
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Im using a singer 57815. Im having a problem with the thread bunching up at the underside of the fabric. Its not the bobbin thread that's binding but the top thread is bunching and getting stuck...
Hello
Reduce the thread tension to a lower number,Select a larger size needle,Remove and reinsert a new needle, flat side toward the back of the machine
Aug 02, 2011 | Singer 57815 Mechanical Sewing Machine
Bobbin thread bunching upu
It is your top threading, rethread and try this test, with the presser foot up, pull top thread, now lower the presser foot and pull the thread, it should barely move. This should seat your thread in the tension discs correctly. Also, change your needle to be sure that you don't have a burr on it from other projects.
Nov 20, 2010 | SINGER 7470 Sewing Machine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Mar 23, 2009 | Singer 132QRFB Mechanical Sewing Machine
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 7436 - INGENUITY Logo
726 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
