Wireless Keyboard cutting out
I have a Microsoft wireless keyboard paired with a wireless mouse...they both use the same receiver. The mouse works fine, but the keyboard has begun to cut out intermediately...so that I have to press a key 4-5 times before it works. I opened up the keyboard and noticed a black wire (about 22 gauge) running around the entire inside of the keyboard. I assume this is the antenna...and I noticed that it is frayed in several places where I can see the bare wire. I'm wondering that if this is in fact the antenna wire, that I should be able to just replace it with a strand of say, speaker wire. Would it still transmit the signal? Would I need something with less insulation...or even a special wire? Or would even a bare wire work? Seeing as theres no metal around the inside of the keyboard and thus no where for it to short out.
  • Pootypantz Dec 14, 2007
    Mine did that too. I found that the battery compartment was a little to large and the batteries tended to fall down towards the compartment door so as to disengage just slightly. So I put a piece of folded paper between the door and the batteries and viola! Fixed!
  • Anonymous Sep 02, 2008
    I was having the same problem and found that moving my receiver closer to the keyboard solved the problem.
    Guru:
  • 82 Answers
You can do so by changing the input language (i.e. keyboard language). Just follow the instructions below how to change the laptop keyboard layout. 1.Click Start and then Control Panel
2.In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner).
3.Open Regional and Language Options for Windows XP; Open Clock, Language, and Region for Windows Vista.
4.Click on the Languages tab.
5.Under Text services and input languages, click on the Details button for Windows XP; Click the Keyboards and Languages tab and then click Change keyboards for Windows Vista.
6.Under Installed services, click Add.
7.In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
8.Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
Posted on Aug 18, 2010
    Sergeant:
    Champion:
  • 293 Answers
I suggest you use the same gauge and watch out for cold solders.
Posted on Sep 14, 2007
SOURCE:
How to connect a microsoft mouse to a microsoft 1447 dongle
The thw wireless mouse is paired from fabric wirh USB dongle for same mouse. You can't connect a wireless keyboard to it because they are no different frequency. Actually it's hightly improbable that you even could connect the USB dongle of a mouse with another different mouse. Explanations is logical: presumeyou are in a big office whate another 1 users have wireless keyboards or "mice". Now, imaginge the mess if the dongle of your keyboard should control the mouse of another 9 usrs.
Now, it's competely different with bloetooth keyboards and"mice"
USB Dongle for Microsoft Wireless Keyboard and Mouse 5000
Apr 08, 2015 | Microsoft Wireless Mobile Mouse 3500
I INSTALLED THE DRIVERS FOR KEYBOARD AND MOUSE, KEYBOARD WORKS FINE, CAN'T GET MOUSE TO OPERATE AND DON'T HAVE THE MANUAL HANDY
You may need to "pair" the mouse with the receiver dongle. Look for a button on each. Press button on the dongle first, then on the mouse.
Aug 28, 2011 | Microsoft Multimedia Keyboard/Wireless...
For 2 years years I have a Microsoft Desktop Receiver 3.1 with a Microsoft Wireless Laser Mouse 5000 v1.0 and a WIreless Laser Keyboard 6000 v2.0. Things were working fine until this morning when the...
Goo0dness, Had this myself just last week. Fortunately I had the old keyboard and mouse and plugged it in to get access. I deleted the wireless keyboard from device manager. rebooted the machine, quickly changed the mouse and keyboard back to the wireless one and it all came back on. saved me buying a new one. Hope this works for you.
Please rate my help++++Thankis for using FIXYA
May 15, 2010 | Microsoft Wireless Optical Mouse USB...
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
Jan 29, 2010 | Microsoft Wireless Entertainment 8000...
I was given the wireless 1045 is there a usb plugin that goes with it ??? If so is it posible that this key board can work offf the usb addapter that I use for my mouse its a microsoft also. the model...
The keyboard is also paired with a wireless mouse. They both use the same USB wireless receiver. If the wireless mouse you are using is not from the set then no, you can not use the same receiver for both.
Jan 09, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Im in an office with three computers that all have wireless keyboards. One of the keyboards keeps typing letters on another computer. How do I stop the signals from being mixed?
I have had a similar problem, when I wanted to run one Microsoft wireless mouse next to my TV and another Microsoft wireless mouse next to the PC in the same room. Both wireless receivers were picking up keystrokes from the keyboard, so the computer thought all keys were being hit twice.
You didn't mention your brand of wireless keyboard, but for microsoft products you push a button on top of the receiver, and then a button on the bottom of the keyboard or mouse to "pair" them. Repeat this step for the computers that are interfering with each other to solve your problem.
Find these steps laid out for you at the microsoft website here:
http://support.microsoft.com/kb/838398
Sep 19, 2009 | Logitech Cordless Desktop S 510
Can't install Microsoft Wireless Desktop
you need to resync the mouse and keyboard to the wireless receiver. you hold the button down on the receiver until you see a flashing light and then you press the button on the bottom of the key board. then you do the same thing for the mouse.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Feb 27, 2009 | Microsoft Wireless Optical Desktop Comfort...
Microsoft Wireless Laser Mouse and Keyboard Cut in and Out
Hi, I'm not positive but it sounds like your memory needs to be incr4eased. How much memory do you have installed now? This effeminately would cause the problem. Bud
Jan 02, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Set up of a Microsoft wireless keyboard & mouse
The devices probably came with a USB cable and a receiver, or just a USB equiped receiver, that you need to plug into your computer. Go ahead and plug the cable and receiver into the computer so that your wireless mouse and keyboard has a means to communicate with the computer. Next, Here is a website address where you can download drivers for your mouse and keyboard. You must first choose either mouse or keyboard, then the exact product and model, then the operating system, and finally the language. repeat the process for the other device (mouse or keyboard, whichever you did not choose first). Good Luck! And let me know if there are any further problems.
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
May 05, 2008 | Microsoft Wireless Laser Desktop 4000...
Open Questions:
Computers & Internet Logo
1,346 people viewed this question
Ekse
Alun Cox
