Result Code: 85 - Hardware Passes But Com Port Is Not Accessible
    Problem Solver:
  • 3 Answers
Make sure it is enabled in bios setting. Usually accessed by pressing function key when pc first starts up POST test and pressing the appropriate function key depending on manufacturer
Posted on Apr 15, 2009
A line with a slope of - 1 7 passes through the points u, - 1 and 5, - 3. What is the value of u?
Slope is usually designed by the letter m. m=delta y/delta x or change in y/change in x or (y2-y1)/(x2-x1).
What we know.
m = -17 (very very steep, with a negative slope, going up to the left)
Point (5, -3)
Point (u,-1)
Putting everything into the above equation, we get
m = (-3-(-1))/(5 - u) , where m =-17
-17 = (-3 + 1)/(5 - u)
-17 = (-2)/(5-u)
To get rid of the fraction, multiply both sides by (5 - u)
-17(5-u) = -2
-85 + 17u = -2
Add 85 to both sides to get rid of the -85.
-85 + 85 +17u = -2 + 85
17u = 83
Divide both side to get u by itself.
17u/(17) = 83 / 17
u = 4.89 (rounded to 2 decimals)
Good luck,
Paul
Oct 24, 2016 | Office Equipment & Supplies
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
The sd port is not accessible. i cant use my card to save files and retrieve files
verify in device manager and verify if there is some hardware which requires driver and then post the hardware id here. if it is not showing then, the there is hardware error
Feb 24, 2011 | Panasonic Toughbook CF-73 Notebook
What folder is reboot in
  • Power is turned on.
  • Open Firmware code is executed.
  • Hardware information is collected and hardware is initialized.
  • Something (usually the OS, but also things like the Apple Hardware Test, etc.) is selected to boot. The user may be prompted to select what to boot.
  • Control passes to /System/Library/CoreServices/BootX, the boot loader. BootX loads the kernel and also draws the OS badges, if any.
  • BootX tries to load a previously cached list of device drivers (created/updated by /usr/sbin/kextcache). Such a cache is of the type mkext and contains the info dictionaries and binary files for multiple kernel extensions. Note that if the mkext cache is corrupt or missing, BootX would look in /System/Library/Extensions for extensions that are needed in the current scenario (as determined by the value of the OSBundleRequired property in the Info.plist file of the extension's bundle.
  • The init routine of the kernel is executed. The root device of the booting system is determined. At this point, Open Firmware is not accessible any more.
  • Various Mach/BSD data structures are initialized by the kernel.
  • The I/O Kit is initialized.
  • The kernel starts /sbin/mach_init, the Mach service naming (bootstrap) daemon. mach_init maintains mappings between service names and the Mach ports that provide access to those services.
Mar 08, 2010 | Apple MacBook Mac Notebook
Need new code for telewest
cf 53 0c 33 79 61 71 85
52 5e 8d 45 fc 75 f6 4a
Try this ENJOYYYYYYYYYYYYYYYYY
Dec 03, 2009 | StarTech.com StarView SV211K 2-port KVM...
Do you have the code for 5a01 pls - 9.10.09
new codes t/w 9th oct o9
oo/ cf 53 0c 33 79 61 71 85
01/ d2 f9 3f 22 0c a7 4c c9
Oct 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
For the Dell Inspiron E1705, a headset has problems with mic
please go to audio properties and test the hardware.
Aug 14, 2009 | Dell Inspiron E1705 Notebook
Result Code: 85 - Hardware Passes But Com Port Is Not Accessible \r\n I am attempting to download/stream a content larger than 400kbps. as of 2 weeks ago I could do that. But now I seem to be able to...
Error Code 85System error code 85 means "The local device name is already in use." This error code may also display as "ERROR_ALREADY_ASSIGNED" or as the value 0x55.
May 21, 2009 | Dell Dimension 9100 PC Desktop
HTC Touch External Port?
Yes, it is technically possible, however it is completely impractical. You would need to gain access to the circuit board, and 'shunt' a port off of the current antenna. This would take a crazy amount of time, so, a hardware hacker would do this as a hobby, not really for pay.
Jan 26, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
