Question about Ricoh Cameras
Ricoh One Take Zoom 105 With a new battery, when the shutter release button is pressed, the camera gives a split second buzz. No movement from the camera. Each press makes the buzz repeat without any action.????
    Brigadier General:
  • 3,614 Answers
it seems that you have a faulty camera.. this could be mechanical problem & thats why the camera lens doesnt retract, try to take out the battery & tap the buttom part of the camera.
if this doesnt solve the issue you may need to bring now the camera to the nearest service center
Posted on Apr 15, 2009
Pictures are blurry
The most common causes of blurry pictures are not holding the camera still and correctly pressing the shutter release button or using a slow shutter speed.
Let\'s talk about properly holding your camera first. Always hold your camera with both hands. With an SLR such as yours, grip the left side of the camera with your left hand and cradle the camera from underneath with your right hand using you thumb and index fingers to zoom. Hold your arms so that both elbows rest on either side of your chest and brace the top of the camera against your forehead. This forms a rigid triangle of support.
The second thing you must do is properly press the shutter release button. Do not poke the button because you will jerk the camera and that can cause blur. Instead, start to press the button gradually increasing the pressure until the shutter trips. It should trip almost by surprise. This is very similar to how a marksman pulls the trigger on a gun.
Assuming that you are holding your camera correctly, not "punching" your shutter button and your camera is not defective, here are two easy ways to solve your problem. First, you could use the manual exposure mode and keep your shutter speed at 1/500 second or faster. Second, go to the "S" shutter priority mode and set the shutter speed above 1/500 second. Your camera will automatically adjust the f-stop (lens diaphragm opening) and "film speed" for proper exposure. Please let me know if this resolved your problem.
Aug 02, 2014 | Nikon D3100 Digital Camera
The shutter of the camera is not closing
Do you mean when you press the shutter release button, oohing happens?
Are you sure you are giving the camera enough time to focus, before you press the button complete?
Normaly, you have to press the button half way, and wait till the camera is focused. The camera will give an audio or a visual signal. Then press the button complete.
Be patient. Point an shoot camera's sometimes need more than a second to focus.
It is not like in the old days, every time you pressed the shutter release button the camera fired.
May 12, 2014 | Samsung TL205 PL100 Digital Camera
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
Olympus C-8080, everything works except the shutter release. I press the shutter button, auto focus is done but "no shutter release". Any ideas? Derek
Does the shutter button feel like it's contacting twice as you press it in? if not, the spring disk in the switch is split; It has happened to me on other cameras on several occasions. Solution is to replace the switch.
If it works otherwise I would suspect the ribbon cable. They can get loose, or the contacts can get oxidized. I don't know specifically about the c-8080, on some cameras the contacts are tinned, which can oxidize. In that case it's a matter of gently rubbing the contact strip with a paper eraser until the contacts become shiny. Of course, that means disassembling the camera ;)
You've probably retired this camera or don't have it anymore but in case you still have it, I hope this helps a bit.
Apr 28, 2010 | Olympus Camedia C-8080 Wide Zoom Digital...
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Opteka RC-4 Remote Control
Hi guys,
S (shutter release), and 2S (2 Second delayed shutter), are the only
operative buttons for an DSLR. The S (shoot), W+T (zoom control), are for select powershot point-and-shoot cameras.
Thanks,
Buzz
Apr 18, 2009 | Cameras
Ricoh KR-5 SUPER II Shutter will not activate.
I doubt you still need help with this considering it's over 8 months later... but the same thing has been happening to me lately, I've had to force the self timer to start by giving it a little push, once it gets going it starts to work normally again.
Jan 19, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
TROUBLESHOOTING c-750
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Nov 12, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Cameras Logo
Top Ricoh Cameras Experts
teddyboy
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
