Question about Cyber Acoustics Portable USB Powered Speaker System Travel Case Computer Speakers
I have an IMac and cannot seem to get sound...
From my speakers when I connect them to the audio output and then connect the usb, they'll turn on and make a crackling noise. The box says they are compatible with macs, why no sound?
    Sergeant:
    Champion:
  • 293 Answers
Is the power On? did you test them in the store?
Posted on Sep 14, 2007
SOURCE:
Recording from DMX 6fire distorted
try isolating the usb that you are using by removing all unnecessary items like extra headphones, cellphones, speakers, battery backup usb connection, you name it. More than likely the static is from that. or try a different usb port if you have removed these items
hope this helps
Feb 19, 2014 | TerraTec Electronic Terratec DMX 6fire...
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
I wanna know how to download a audi device for my pc because it doesnt have one and i cant hear anything.
If your computer doesn't have an audio device, you can't download one. You'll have to get a piece of hardware that supports audio. Go to geeks.com, or amazon.com and get one of the USB sound cards. When it arrives, plug it in to a USB slot, install the drivers, and connect the output to some powered speakers or headphones.
Jun 25, 2011 | Audio Players & Recorders
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I just bought a H2400 monitor with built in speaker. I connected it but the speaker does not seem to work. What am I doing wrong?
Did your monitor come with a separate cable for the speaker? Generally they're short cables with a stereo jack on each end (the same as you'd find on headphones). The cable should be plugged into the back of the monitor as well as the Audio Out Port on your computer (generally you'll have two or three ports - you want the one that's color coded green).
If you have the cable attached correctly, and still aren't getting sound, then you may want to check you system speaker settings. You may have an icon in your taskbar that looks like a speaker, or you may need to open it via the Control Panel. You'll just want to check that none of the channels are muted, and the volume is turned up.
If you need additional help, just respond to this solution and I'll see what I can do to help. Good Luck!
May 05, 2011 | Computers & Internet
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
No sound from sound sticks ... they're almost new
Never mind... I found the USB Output in the "sound" icon on my control panel... one click and sound came a blazin'
Mar 09, 2009 | Harman Kardon SoundSticks Computer...
I want to convert my 3-wire audio output to one wire so I can use
RadioShack is the exclusive provider of 3-to-1 headphone splitters for $7.99. Output is perfect just connect the 3 wires to the output of the splitter.
Dec 08, 2008 | Logitech Z-5500 Computer Speakers
Sony MHC-RV888D Tape Recording to LAPTOP - How to connect?
you have to connect the S-VIDEO output of the device to your laptop via s-video - usb cable , if they do not have a cable like that than you might as well use an adapter from s-video to usb, if u have your hands on one.
the second method is to hook up a audio recorder from the speaker output, and use a volume controller witch steps down the speaker output so you can plug the cable directly to your laptop microfone output..
good luck!
Apr 11, 2017 | Sony MHC-RV888D Shelf System
Cyber Acoustics Portable USB Powered Speaker System Travel Case Computer Speakers Logo
89 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
