Question about Gaggia Syncrony Espresso Machine
Need to find out an address in Scotland to get my home small Gaggia serviced.. pressure pipe keeps falling off.Need of a service but where is the nearest place to do this. Mr Dixon
    Scholar:
  • 192 Answers
Go on line and Google the name of the co. you will find it there. Good luck DFD
Posted on Apr 15, 2009
Water comes out bottom when brewing
If you can safely remove the top of the machine, check carefully the pipes running from the pump to the brewhead, and the bypass line back to the water tank. Most machines use hard plastic joiners in the lines, and these are notoriously susceptible to failure after a while, probably due to the combination of temperature and vibration. The connections on the pressure relief valve near the output of the pump are most often the culprit, probably because it is subjected to pretty savage vibration. You may have to run the machine briefly with the top off to see where the leak is occurring. Be VERY careful if you do and keep well clear of all wiring etc while it's plugged in! There is a slight chance that one of the silicon rubber pipes has split, but that is a very small chance indeed.
Nov 12, 2013 | Gaggia Titanium Espresso Machine
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
Hi, the hot water outletpipe( i don`t know how to say it in english) keeps leaking water. If the machine is heating up, tehe pipe allready starts leaking and keeps doing it. The machine is only 8 months...
Do you mean the "steam wand" ? The pipe you would use to steam milk?
That sounds like the steam valve needs replacing or rebuilding. If the machine is only 8 months old it is still under warranty. You should contact the store where you bought it or contact Gaggia service center in your country.
Sep 21, 2010 | Gaggia Titanium Espresso Machine
We have inherited a gaggia titanium which has done about 2500 coffees. Although the coffee runs through ok, the steam and hot water pipe does not run at all and the machine says "ventilate" regularly. I...
You might have to replace the steam valve assembly, try to get the stainless steel valve instead of the plastic one if your machine does not have it already. You can get the parts from your nearest gaggia dealer or from servicesunlimited, if yo check the importika.com web site you will find a list of all services agents and dealers.
Jul 28, 2010 | Gaggia Titanium Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
Dec 17, 2009 | Gaggia Titanium Espresso Machine
Service centre in Mumbai India
Service center for Gaggia, Lapavoni in Mumbai<br />ID gourmet India Pvt Ltd.<br />Appasaheb marathe marg,autohanger,prabhadevi,mumbai-400025<br /><br />contact:- Shrikant Shinde<br />Service Engineer<br /> 91-9594980001<br />
Apr 18, 2009 | Saeco Incanto Classic Espresso Machine
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Lack of water pressure
Try Descaling your machine with Descaling solution. Your group head may be clogged with calcium deposits which will cause a pressure loss.
If you need descaler you can purchase it at http://cerinicoffee.com/Dezcal_descaler_4pack.asp
Authorized Gaggia Service Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Aug 18, 2008 | Gaggia Baby Espresso Machine
Gaggia Syncrony Espresso Machine Logo
60 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
