I have an HP PL4260N Plasma TV. When I click source on my remote, all entries on the list are "cable". When I first bought the tv, it listed out all the different connectors (eg HDMI, Svideo, etc.). Now the entire list is Cable. Is there a config I can select to get the comprehensive source list?
Did you just install a cable box? Is it in between your other sources and the TV? If it is, try changing the imput on the cable box instead.
Same Problem
Apr 15, 2009
-   No. I have a Yamaha Amp between the DVR and TV all connected by HDMI cables. The Wii is connected directly to the tv using component, and I also have my laptop hooked directly to the tv using the standard projector port. The TV used to show the list of all connections (HDMI, Svideo, Component, etc etc) when I clicked "Source" on the remote. Now all the entries on the list read "CAble"
-   Guest
Video board is most likely damaged from a electrical spike, you may try looking at the capacitors on the boards inside the tv and see if they are damaged capacitors are an easy solution to problems some of the time.
Was this helpful?
Yes
No
Popular Solutions for HP PL4260N 42 in. HDTV Plasma
how to diagnose defective components in a large screen lcd or plasma ''television''? There are...
(More)
how to diagnose defective components in a large screen lcd or plasma ''television''? There are tricks for bad inverters, back lights. How about symptoms that point to main board, Y SUS/Board, Z SUS/board, Y Driver, logic board, etc?
the menu keeps popping up continously on my screen. i have a 42 inch philips plasma t.v. model...
(More)
THE MENU KEEPS POPPING UP CONTINOUSLY ON MY SCREEN. I HAVE A 42 INCH PHILIPS PLASMA T.V. MODEL 42PF9630A-37. I REPLACED THE BATTERIES ON THE REMOTE, BUT THE MENU KEEPS ON POPPING ON THE SCREEN.
when i get a lot of dark colors on the picture theres a lot of white dots on the screen. ive tried...
(More)
when i get a lot of dark colors on the picture theres a lot of white dots on the screen. ive tried to reset all the setting on the TV and even bought new cables thinking that it might be my connection. its not the sat device eather cause it does it when i use my BlueRay any idea or other people having this issue? ty
