Question about Garden
How do I raise the mower and remove the rear wheel which is punctured on a Hayter Heritage 13/30?
  • 10865 Answers
SOURCE: I have a yardmaster ride on mower with a puncture
chances are that rust is the culprit here. you can try hiitting the wheel using a block of wood against it and then a hammer. Another approach would be to bock it up and either use tire slime to make the repair or insert an inner tube. Of course you will then need a way to blow the tire up which could be a compressor or a portable air tank.
Posted on Mar 09, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 89 Answers
SOURCE: Removed bolt but still can't remove rear wheel on
they sometimes are very haed to get off some wheels have two holes on the rim you have to use a gear puller
Posted on Nov 05, 2009
  • 11800 Answers
SOURCE: Greetings, I am having great trouble removing the
The wheel is kept in position just by the central bolt pressing the rim on the flange. If after removing the bolt the wheel doesn't slides out then it's been sealed in by dirt and rust - pound it out - use a big rubber mallet and a piece of wood.
Posted on Feb 26, 2011
  • 46177 Answers
SOURCE: How is the rear wheel of a Hayter Heritage removed?
most of them have a split ring or snap ring that needs removed then the wheel just slides off . manu rust in place and need persuasion to get off .BRUTE FORCE
Posted on Jul 30, 2016
Blade not turning hayter heritage 13/30 ride on
Your seat switch may be bad.
Oct 14, 2017 | Garden
No spark at plug
Remove small kill wire to coil see if it will start if so you will need to find where this wire is grounding out.
Sep 09, 2017 | Garden
Jul 30, 2016 | Garden
Briggs instructions
Locate the drain plug on the bottom or side of the engine (might have a drain pipe attached to it) remove plug let oil completely drain screw off filter and replace (if equipped) refer to manual or Google and find out how much oil the engine holds (maybe around a quart) replace oil check for leaks and go mow your grass
Aug 15, 2014 | Briggs & Stratton Garden
Wheel stuck on shaft
make sure there aren't any c clips holding it on I would use a block of wood and a hammer I have put green slime in my tires that stuff works great it should fix your tire
Jul 26, 2013 | Toro Garden
Rear wheel stuck on shaft
should be ale to take the lug nuts off and simply take the tire off if it is stuck on after taking the lug nuts off take a 2x4 and hit the back side of the rim a untill it comes off they do tend to stick on the hub.
How can I refit the drive belt from blade shaft to driving wheel gearbox on a Hayter R48 recycling mower?
I did it with a large screwdriver. Pressing the band with the flat end of the screwdriver pushed the drive band back under the drive wheel behind the gear mechanism at the rear of the mower.
When it was back under, manually rotating the blade made the band run free over the drive wheel
Sep 18, 2010 | Garden
Can you use Fix a flat to repair a flat tire on the Cub Cadet LTX 1042
If it's a simple puncture, "Fix-a -Flat" or another product called "Slime" might work for you. I believe Walmarts sells both.
Hope this helps... Good luck!
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
TRANSMISSION LOOSES PULLING POWER AFTER WARNING UP
the first step is to replace the air filter you'd be suprisied.then the fuel filter .take a test run after that.hope this helps
May 10, 2009 | Garden
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
