Washer will not spin or agitate. I hear motor running though.
My Maytag washer model A208 doesn't agitate or spin. Its an older model and I hope I can get parts!
Hi. This happenes to me all the time. From what I understand, it's caused by a small part that gets too much pressure on it and breaks when people overload the washer. The part needs to be replaced. If you call Maytag they can probably tell you exactly what it's called, but as for installing it, I don't know how. But for the future, what we think of as a full load is actually overloading the washer. Try not to go more than about half full and then always set the water level on high. This puts less stress on the part. But this is not a big deal. I'm 99.99999% sure this is your problem and if you buy the part, you might be able to sweet talk them into telling you how to install it. You'll save yourself about $100 bucks. Good luck!
Posted on Apr 15, 2009
Draining but not spinning
if it doesn't spin or agitate but you can hear the motor running check the motor coupling,common problem with whirlpool washers
http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps and good luck with your washer,or you could have a bad transmission but check the coupling first,part 285753A and it's around 20 dollars
Mar 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Jul 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Old maytag A208 will not spin
I would say, there is something holding the inner drum from rotating. Possibly an item of clothing that has slipped between the drums.. When washing only the agitator(pulsator) moves, when spinning, the complete drum rotates as well. Remove obstruction.
Sep 21, 2009 | Maytag PAV2300 Top Load Washer
My washer ia an older maytag and it will not drain or agitate i hear a quiet buzzing noise on the spin cycle cut does not move. I can hear a click when i open and close the lid not sure on model #
IF YOURE HANDY WITH TOOLS , THEN open
WASHER and check the DRAIN MOTOR PUMP , it could be clogged , locate the motor pump by following the DRAIN HOSE where its connected , remove , clear of any debris or lint , replace and try again , AJ
Jun 04, 2009 | Kenmore 15864/15862 Top Load Washer
Maytag washer won't agitate
your transmission is no good and needs to be replaced
Dec 14, 2008 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
