Question about Garden
What goes where
14'' ryobi chainsaw throttle linkage set-up has come apart
  • Anonymous Apr 16, 2009
    I had to split the plastic casings to repair a broken rope.As i opened the casings some parts dropped out, namely two plastic pieces that fit in the rear handle for throttle lock...that is ok.. but uncertain of spring position.The spring has to return the rear handle lock release to normal position.What i need is an exploded diagram of the chainsaw parts showing their positions. At the moment its trial and error until i find the correct spring position. The model is an Australian RYOBI RGS3214A ...14 INCH.. 32 CC ENGINE
  • dontbother10
    dontbother10 May 11, 2010
    We need the make, model, and serial numbers from the manufacturer?s tag to help you farther.
  • 157 Answers
You will have to go online to the saw makers website and download a scehmatic of that part of your saw
Posted on Sep 18, 2009
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Ryobi C4620 chainsaw idles too fast
I had this same thing . Its in the throttle cable tube. take the cable away from the carb. cut about 1/4 in of the tube around the cable off reattach to carb it works for me!
Apr 23, 2014 | Ryobi DOUBLE D - CARB ADJUSTING TOOL...
Chainsaw runs fine than goes full throttle all by its self and cannot shut it off with switch.
Kill switch is broken or disconnected. Throttle linkage is broken or disconnected or idle is set way too high.
Oct 26, 2013 | Craftsman 2.5 Turbo Chainsaw Throttle...
Throttle down linkage
Open up handle and check for alignment on trigger and parts. You can look at an exploded view to see all the handle and trigger parts.
Sep 06, 2013 | Stihl MS181 14" Chainsaw
Ryobi chain saw wont throttle down to idle
check the choke linkage it props the throttle open
May 20, 2012 | Ryobi Garden
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
When chain saw is starte it goes to full throttle.
You understand there is a fast idle start position? If your saw is new it is triggered when the choke is pulled and remians in this position (even when choke pushed in) until the throttle is advanced once. Read your warm start instructions, it says pull clutch, push clutch, start. This is why we should buy saws from a chainsaw seller/mechanic NOT Home Depot!!!
I made the mistake ONCE of attempting to start mine without the fast idle engaged... my shoulder aches just thinking about it. GL
Lou
Sep 13, 2009 | Husqvarna Garden
Crafstman chainsaw at full power when started
If you had this apart, a few things may have happened. First the linkage from carb to throttle trigger maybe jammed between plastic housing or linkage may have come apart and throttle is in the full open position. You'll have to take this apart again and follow the linkage between carb and throttle trigger to ensure all is connected and moving freely and properly. Use care when putting housing back together.
May 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
