Question about Mitsubishi WD62628 62" Projection HDTV
Lamp just blew
Can I get the lamp and install it myself.
  • Anonymous Mar 10, 2008
    my tv will turn on but ** picture will apear, the green light will keep on blinking until the tv will go off by it self and then a solid red light will apear, I try the reset button but it did **t worked, please help me solve this problem, do I need new lamps???????
  • 790 Answers
If you have experience in electronic repairing why not! but if not! dont do that! coz that is sensitve intalling and they have high voltage to harm you! get authorised tecnician for best result. havce a good day!!!
Posted on Sep 14, 2007
How do you relace lamps on plasma tv
New to this, I to have noticed top line dark left to right. Never thought to change. Will have a go myself, wonder were lamps obtained from, try google search. Yeah
Sorry not to answer question, should think it is a screw driver job and patients including health and safety measures. If you do, make sure plenty of cloth material to rest screen
Jul 21, 2014 | Samsung Televison & Video
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Hitachi 50v500a: Lamp blew, oredered a replacement. Just installed it, and I still get the "lamp" light on and it wont power up.
Remove lamp and look to see the socket the lamp plugs into did not get bent out of position---just check to see if it went in right and after that you put the door back(set will of course not operate if door or cover removed).
If we assume New lamp good and installed correctly the next possible issue is the Ballast which powers the lamp--Not easy on this set to check voltages---should have a plug with over 200-300 volts from power supply going to--the two wire plug from the lamp goes directly to it.
Apr 04, 2012 | Hitachi Televison & Video
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
LAMP light blinking after replacement.
Lamp Fan or Ballast board,problem could lead back to Dmd Module Encompass Parts Distubtion has what you need for this Set 1-800-638-3328
Feb 24, 2010 | Samsung HL-P6163W 61" TV
Lamp on my infocus 4805 keeps blowing. This is the 3rd one.
don't forget to clean your pj all 250 hours of utilisation!!
Mar 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a WD52528 and it turned off and the lamp light came on.
I had the same problem took it in and it was the bulb had over heated and blew out. The bulb is $199.00(here in wisconsin).After teh repair i called hitachi they told me i could have done it myself without having to take the tv in...Hope this helps.....
Jan 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Bought new projection lamp, want to install it myself--how to??
The best instructions for replacing the lamp can be found in the owner's manual. You can get a free copy by copying the following address into your browser:
http://www.docs.sony.com/release/KF50WE610.pdf
Dec 24, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Mitsubishi WD62628 62" Projection HDTV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
