Question about Pioneer SD-P55A3-K 55" Rear Projection Television
Blown 4 amp fuse twice
TV would click on/off no picture. replaced the 4 amp fuse Tv worked for 2 weeks , replaced 4 amp fuse again and this time TV did not come on.
  • 790 Answers
Ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Posted on Sep 14, 2007
When I power up I hear a clicking sound. Goes into stand-by mode
I am having the same problem. It happened today for the first time. This morning the TV was working, now, in the afternoon, I tried to turn it on and I get no image. I can't even access the Menu, therefore I have to stick with the HDMI connection, eventhough it would have been a good idea to try other inputs.
Dec 12, 2009 | HP PL4260N 42 in. Plasma HDTV
SONY KV-32S25 TV SHUT OFF...NO POWER NO SOUND
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
When I Turn on my toshiba 32AV500U there is sound but no picture
The problem isn't with the lcd panel, its with toshiba not willing to sell the backlight master or slave inverters seperately from the panel. If you check either the master or slave will have a blown 5 amp fuse, ussually 2 or more transistors inline with the transformer will be shorted.
Nov 16, 2008 | Televison & Video
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Samsung Flat Screen Won't turn On
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Apr 02, 2007 | Samsung TXN3275HF 32" TV
Had power surge? When plugging in or turning on the unit I hear clicking. No picture.
Mine had the continuous blinking , and sometimes 2 blinks after trying to turn it on again. I was given the tv and after checking it out found two blown T3.15 amp glass fuses on the audio amp. T for time delay. I went to a recycle center and bought two complete chassis for my model kp53s25. I started changing the standby power supply first. Still did the same thing. I changed the high voltage board with the smaller transformer only and leaving the other larger high voltage transformer in the set. I just cut and spliced the single connecting high voltage line between the two high voltage transformers. Still had the same problem. I change the audio board and the set would work until I believe the audio board heated up or had an intermitant short and the tv would shut down. I replaced the full audio board with another and now the tv stays on and is working great. There seems to be a overheating problem with the sony audio board and i may buy a muffin fan to fit over the audio boards large heat sinks for added cooling in the rear right hand corner of the tv . Touching the heat sinks after tv has been on a while is very warm. Find a recycle center as I bought the parts I needed for 10 dollars for two complete chassis. I should have keep the color projection tubes.
Nov 17, 2006 | Sony KP-46S25 TV
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
199 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
