SOURCE: I have a toshiba a135. the screen has a red color
You have some kind of intermittent problem with onboard video or video connector, you must replace it.
Sergio
SOURCE: blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
SOURCE: My Toshiba p105-s6064 display screen is only
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
SOURCE: Toshiba A205 S5804 no backlight
You need to check and see if you have 12vdc feedind the inverter board, there is a very small surface mounted fuse (Fx) ion the inverter board, just put one of the meter lead to metal part of the laptop, and anothe lead on the fuse (check both side of the fuse). Is the inverter board new or used?
SOURCE: I need toshiba satellite A55-S1064 utility/drivers
You will need to call Toshiba's tech support line and get a new disk. Be careful to get the correct disk. I had them send me the wrong one once and I was frustrated for days.
