Question about Canon iR 2022 Printer
Dear Experts, We have just got a Canon iR2022 Copier/Printer. The copier is working properly but for the printer here is the scenrio. The printer is on the network no net work issues. i have installed
Dear Experts, We have just got a Canon iR2022 Copier/Printer. The copier is working properly but for the printer here is the scenrio. The printer is on the network no net work issues. i have installed it on our Print server through TCP/IP port configuration but now when i print something and when i check the status through the web browser config of the printer my print gets stuck and the printer shows error which says no paper Loaded please Load paper. i have set both paper settings to A4 on machine and on server and but still the printer shows the message to Load the paper however all the drawers has paper. Your help is required Thanks, Aryan
    Problem Solver:
  • 16 Answers
If it hapen´s just after you acces it via web and if you turn it off and back on everything get´s right your problem is the firmware.if it´s your problem call me back.
Posted on Aug 05, 2009
Hello i have a canon ir2022 displays "load paper drawer 1" at start up.
If there is paper in drawer 1 and you still get this error, it sounds like a bad paper sensor.
May 27, 2015 | Canon imageRUNNER 2022 Grayscale Copier
How to set ip address in canon ir2022
You will need to log into the "Admin" section of the copier.
Then go to the network section.
You should have a manual with it for default user/pass and how to enter IP. Manual: http://software.canon-europe.com/products/0010473.asp
Jan 21, 2015 | Canon Office Equipment & Supplies
Error code 002-0000 for canon ir 2202
Hi
A website I have found gives the details of this error for the IR2016 and the IR2022 as the same.
Description Low temperature during temperature control.
The target temperature is not reached during temperature control. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Amongst other codes you can find it here:
Error Codes Canon iR2022
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon iR 2016i Black and White Copier
Dear sir i has a copier Canon IR2022 when i copy a file it give message ( system error 007 or system Error 003) how can i resolve the problem. thank you much
Possible torn out fixing film. Or dirty reference white plate on your fixing film. To resolve the problem, try replacing the fixing film unit or call the nearest authorize service center.
Aug 14, 2013 | Canon iR 2022 Printer
Service manual canon ir 2022
hello friend, you can find the canon iR2022 service manual in below link:
Canon iR2022 service manual:
http://goo.gl/n2Rc95
thanks
Jun 15, 2013 | Canon imageRUNNER 2022 Grayscale Copier
How i do scanner in canon ir2022
connect computer to network
install canon color network scangear, select printer ip in this software.
now you need scanning software.
I'm using freekapture.
place document in printer scanner. click scan button on printer.open freekapture and start scanning
Jul 06, 2012 | Canon iR 2022 Printer
Hello I have a canon ir2022 copier. I did a complete cleaning of all copier and when I recovered after having switched on a message error code e197. I controlled everything but I can not get from this...
Dear Mokhtar,Error code E197 indicates that laser scanner does not work properly. It's seems that you should try to replace this parts (Laser Scanner Assembly). Please download the following piece of IR2022 parts catalog to see detail of laser scanner assembly:Laser Scanner Assembly
I'm sorry for being late responding your problem and you don't have to pay for this :).
Regards,Xanda
Oct 03, 2011 | Canon iR 2022 Printer
Canon iR2022, now: "drum is
check the drum insert flag in the drum unit(front side).it has to be intact as it has to match the sensor when the drum unit is inserted. u can see it when u insert the drum unit it is it at the front of he machine.u can also bypass it by placing a paper int the sensor
Jul 21, 2011 | Canon iR 2016i Black and White Copier
My scan gear software cannot list the cannon ir2022 copier. The Ethernet network plug also doesn't blink when connected to the slot in the copier? please respond me with ermiasabate@gmail.com thank you
first are you sure that you have correct network cable, plain utp if you use copier over hub or similar and cross if You are connected directly trough PC.
Under cmd, type: ping xxx.xxx.xxx.xxx. "x" means the IP adress, if you have replay without 100% loss, the copier communicates fine with pc.
If not use cross cable and connect directly to pc or laptop.Do not forget adjust laptops gateway, and subnet same as copiers.Then try again from setup of printer drvivers and scangear. Do not forget to press discover under scangear properties.
Dec 26, 2009 | Canon iR 2022 Printer
Ir2022 memory full message
Check your printer spooler queue.
Sounds like a big job went to the printer and filled up its memory. Cancel the job and reboot the computer.
Dec 02, 2009 | Canon iR 2022 Printer
Canon iR 2022 Printer Logo
446 people viewed this question
old marine
old marine
