No beep while boot
My comp has no beep at all while i try to turn it on. how to fix it ?
  • Ryan Stiers
    Ryan Stiers May 11, 2010
    Does the power light come on at all? Also, on the back of the computer where the Power Supply is (usually near the top) there may be a green LED Light. Is the light Solid Green or is it blinking continuously?
  • Computers & ... Master
  • 5,660 Answers
I suggest that either a ram module, (Stick) has come loose, (Or more than one), or the power supply is bad, or the Power On switch (button) is bad.
Posted on Apr 15, 2009
I am having problem with my computer. Initially it started with a Beep everytime I use to boot the computer, it gave me a message after the beep that " Your password expires in 14 days do you want to...
hi nitind
  • It's not big problem
  • re-boot ur system
  • you r telling you r upgrade your pc,so it supports windows7 too
  • put a new copy of windows 7 original
  • if not means disable the windows update after installing ...
  • before the problem may arise due to corruption of files or password is not a valid one ..
  • so put a fresh copy of windows in which drive already you have os...
  • other drive data must be safe...
  • keep antivirus active this must be helpful for your pc ...
Dec 25, 2010 | Computers & Internet
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
Computer powers on, no beep, monitor is blank
open the tower, on the mother board you will find the RAM card approx 6 inches long, take out the card and restart the comp, you should get the beeping sound and the mother board is fine, if no beep that indicates the motherboard has gone bad.
place the ram card properly into the same slot and then restart the computer. NOTE while putting your hand into the comp components always make sure that the pwr cord is pulled out or else you will get shock.
also check the cord at the back of the harddrive should be fixed properly. take it out and refix it at both ends . probable cause is there is some loose connection of the cord or the RAM.
May 10, 2010 | Computers & Internet
Not booting, 8 short boots, but VGA card
plug in the moniter.... mabbe that helps... or buy a new comp easy fixed
Apr 10, 2010 | Mercury P4VM800M7 Motherboard
Have Comp. w/Asrock MOBO.It's been sitting
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
Wont boot up when i turn it on it just beeps 6 times then stops beeping for a few sec then beeps again it worked finr last night what happened and how do i fix it pls help i love this comp PLEASE HELP...
6 Beeps: Keyboard controller / gate A20 failure
Explanation: The keyboard controller is a chip on the motherboard that communicates with your keyboard. It also controls the A20 gate that provides access to the high memory area (HMA). This component is indicating a failure.
Diagnosis: This is usually a problem with either the keyboard or the motherboard.
Recommendation:
Troubleshooting the keyboard is relatively easy; try that first.
Troubleshoot the keyboard controller.
Troubleshoot as a motherboard failure.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 14, 2009 | HP Compaq dc5100 Small Form Factor PC...
Asus A8M2N-LA MOBO fans spin but no beeps or anything else
try by switching on the comp.without ram ,check weather the motherboard gives any beep
If No then take out motherboard from chassis ,and try to power on the comp. with some barrier bet chassis and mother board
Mar 15, 2009 | Computers & Internet
Matsonic ms9087c boot hang and beeps
Try re-setting the bios jumper, it's by the battery.
Jan 01, 2009 | Matsonic MS9087C Motherboard
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
Sep 16, 2008 | HP Compaq d530c PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
