Question about Hotpoint VBXR1090B Top Load Washer
Hot/cold cycle works but w/out hot water
When i put my washer on the hot wash it will fill up, but only with cold water. is the hot water generated by something in the washing machine or from my house water heater. the water to my sinks, bathtubs and showers are hot.
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Posted on Jun 08, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Hotpoint VBXR1090B Top Load Washer Logo
98 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
