PSP Video formats supported:
Video: MPEG-4 (aka MP4), AVIAside from movie and music videos available commercially on UMD, the PSP can also play video files from the Memory Stick. These files must be in MP4 or AVI format.
VMusic: MP3, ATRAC, MP4, WAV, WMAMusic can come on UMD (though usually it comes in the form of music videos). You can also load your own music to play, as long as it's among the formats listed (you may not be able to play some of the file formats if you're using a Memory Stick Pro Duo, though; only the Memory Stick Duo is compatible with all file formats).
DVD to PSP Converter is a professional DVD ripping software which can convert homemade DVD and encrypted (rent or purchased) DVD to PSP video and audio files like MPEG-4, AVI, MP3 ... and these converted files can be played on PSP, PSP 3000 and PS3.
What's more, this DVD ripper can edit DVD, it can help you clip DVD segment, crop DVD size, edit DVD effects, adjust subtitle, and add DVD watermark, to get the customized DVD video and audio files.
The following is a step by step guide on how to
convert DVD to PSP with the DVD to PSP Converter.
Step 1: Download and install
DVD RipperStep2: Add DVD disc or IFO file
This DVD to PSP software supports to import two kinds of DVD (DVD disc and IFO file) Click one of the "Load DVD" icons.
Step 3: Select output format
Click the triangle on the right of the "Format", you will see the drop down list, it lists many popular media players such as iPod, iPhone, iPad, PSP, BlackBerry, etc, so you can choose the right formats according to your media players.
Step 4: Output Video Settings
Click the last icon on the tool bar , you can customize video and audio parameters on the pop up window by choosing from the drop down list of these parameters.If you don't know how to set the correct parameters manually, you can just click "Low" or "Mid" or "High", but you should know that high quality video contains large size and vice versa.
Regular DVD movies usually have several subtitles such as English, French, German, etc. You can select one you prefer. You can also delete the subtitle by selecting "No Subtitle". Selecting Audio is the same. What's more, you can also choose a proper output path as your destination folder for the converted movies.
Step 5: "Start" Conversion
Click "Start" button to start the
DVD to PSP conversion. And you will find the output files by click "Open".
