Question about Electrolux Refrigerators
My electrolux refrigerator works for 7 to 8 hours and then going off as the mcb is also going down. I cannot restart the fridge as the mcb is going off as soon as i switch on the fridge switch. After again 8 to 9 hours when i switch on the fridge it works for 7 to 8 hours and problems continue like this...
    Loyalty:
    Visited the website for 30 consecutive days.
  • 509 Answers
Your compressor is overheating and pulling higher than normal amperage .Check to make sure all the fan is working and your coil is clean
Posted on Jan 03, 2018
  • 14 Answers
SOURCE: Fridge not cooling down
The most likely cause is a gas leak . Call a technician.
Posted on Jan 24, 2008
  • 1314 Answers
SOURCE: compressor problems
it varies with door oppenings stuff like that sounds like you may have a faulty cold control the cold control has two settings a cut on setting and a cut out setting you cut in setting may be bad id replace the cold control
Posted on Mar 15, 2008
mikedurland
  • 481 Answers
SOURCE: froze but won't could
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 27, 2008
  • 89 Answers
SOURCE: ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Posted on Aug 24, 2008
woodchuck789
  • 4070 Answers
SOURCE: I have a 4-yr old Electrolux 22.6 counter-depth
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Jan 07, 2010
Transported fridge now wont start
Be sure there is still power to the unit, could be stuck in defrost and need a new defrost timer
Dec 01, 2013 | Electrolux ER7620C Refrigerator
My E123CS55GS Electrolux Side by Side Refridge is not working on the refridge side. The "High Temp" light came on, so I 1) checked the door to ensure it was closed tight, 2)Checked Fridge setting- Set at...
when temperture is droping its a good indication it fuctioning properlt but when the refrigerator doesent go down to the desired temt of 37 you may have to clean the coils in back of the refrigerator this can be done easily as it worked for me you can use a aircompresor to blow any heavy dust the unit has acummilated or you can use a soft brisle brush even a tooth brush is good in hard to reach areas.
Sep 09, 2013 | Electrolux EI26SS55GS Stainless Steel ...
Electrolux Inspire ENB35405W fridge freezer faulty
Empty it and defrost it completely (24 hours with door open) restart it and check the fridge has cold air again. check the defrost setting on the controller. Also check the drain pan on the back of the unit as it may be overflowing or have a crack in it. Is it still under warranty?
May 01, 2017 | Electrolux Refrigerators
Electrolux Side by Side Fridge-Freezer ESE6108WA - freezes food in the fridge
hi its sound thermostat problem not click off when the temperature reach to the set point ,need to replace it.
May 14, 2012 | Electrolux Refrigerators
Cannot get fridge to go down in temp - it is above 15 degrees. Freezer is working well.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Electrolux Arthur Martin ARA4262
Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
May 12, 2010 | Electrolux ER7626B Bottom Freezer...
Fridge runs good for 3 to 4 hours.then turns on but does not cool. i unpug for about an hour and then cools good for another 3 to 4 hours
Are you sure the compressor is turning back on. I would bet that you have a tecumseh compressor in your fridge and when they get hot they don't restart till they cool. The bearings in them go bad. We replace those with Embraco compressors. You unplug it and let it cool down and that is why it restarts.
Sep 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Acquired second hand electrolux er3167bn fridge freeze. worked ok for about 10 days then fridge started to get warm, eventually ended up room temp. engineer said to switch off fridge freeze and leave for...
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
May 02, 2009 | Electrolux ER3167BN Bottom Freezer...
Hi i have an older electrolux 120 gas fridge,the piolet light is going but does not cool down.thinking it needs re-gasing if so where on the sunshine coast and how much
sounds as though this is an absorbtion type fridge and hence no gas! in any case, refrigeration only needs regassing when there has been a leak
Aug 31, 2008 | Electrolux Refrigerators
Refrigerators Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
