Ineed to hook up the me-70 to a b-52 head and crate cab
    Brigadier General:
  • 3,614 Answers
may i know wht model & brand that you have?
thanks
Posted on Apr 15, 2009
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have an old crate blue voodoo amp head that wont work
Good day sir, changing the tubes won't solve the problem, sad to say it but you may need to bring it to a veteran technician, that knows tube amps. there are simply lots of things to check for. hope this helps, thanks
Jul 19, 2009 | Audio Players & Recorders
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
My Crate blue voodo amp head
Hi...
1st off , check the connections from the head output jack to the speaker cab. If you can get hold of a meter , check the continuity on the cable (center wire to center wire , ground wire to ground wire) both should be about 0 ohms.
Do you have another speaker cab you can try>?
You might have a speaker fuse internal on the amp too OR a secondary fuse on one of the power supply lines
Dec 21, 2008 | Audio Players & Recorders
Crate spa 400
you might need to see what your volts are if there 14.4 at the amp thats good but see what they drop to ....
Jan 01, 2008 | Crate SPA1600 Power Amplifier - SPA Series...
Volume problem with BV120 tube head
hi.i suspect it is not faulty just built with different gain characteristics.only a power check with an oscilloscope will tell and any electronic repairer should do this for you very cheaply.it will also tell you how well and balanced the valves are.if you are near leeds.uk.i will do it for you nigel
Oct 25, 2007 | HHB Radius 50 Tube Amplifier
Crate BV120 too quiet
Have the tubes checked when good and warm.
Check for any leacking capacitors.
Check all solder joints are shiny any that are dull try to reheat and apply solder.
Good Luck
BIGRED
Oct 23, 2007 | HHB Radius 50 Tube Amplifier
23 people viewed this question
 Grubhead
Grubhead
