Samsung Transform Ultra Logo
T Ray Posted on Sep 10, 2013
Cant turn off usb storage with no cable hooked up also beeps to say that it is connecting and disconnecting when not. Same as my last s.t.u. before screen went black.
Delta38
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Sep 10, 2013
Delta38
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
372
Points
25
Ok if u have a sd in there with all you data on it take it out then hook it up to the computer and then take all data off the phone like drag it all out to the recycle bin then take the batery out the phone an turn it on
1helpful
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Cant get my phone mp3 to play through my stero
When you hook up the phone to your stereo did you put your phone in mass storage mode? It has to be turned in to storage mode in order for the phone to connect to the stereo. Try it and get back to me....
2answers
How do I transfer pictures from my Samsung phone to my computer?
Which model samsung ? Im assuming its an Android handset.
Plug in the usb cable to your PC/Laptop and also the phone, your phone should beep. Now drag down the top bar and select the usb connected notification, and turn it on.
Wait a few moments and it should popup on your screen, select view files and folders.
Now just drag the pictures over to a folder on your desktop.
Option 2 (lazy way)
Download the photobucket app from the Market, create and account and login. Upload the pics, when its finished visit www.photobucket.com on your computer and login with the same details and the photos will be there.
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
113helpful
3answers
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
F..ked up
Try a different USB cable and different USB ports. Lots of times it's the cable.
Try holding the power button "UP" for 15 seconds, wait a few moments, try turning on and off then reconnect to computer. This resets the unit.
Force MSC mode - power button "DOWN" in hold (orange showing), press and hold CENTER button while connecting USB cable (& don't release CENTER button until unit is recognized). You won't be able to transfer DRM-protected content but it might just fix what's ailing you.
Hope this helps.
2answers
TRANSFORMIN PHOTOS FROM OLD CELLL PHONE
How can I transfer files between my PC and my phone? space.gif space.gif answer.gif To tranfer files between your PC and your phone:
  1. Your phone can upload and download files when connected to a PC running Windows 2000 and higher. Mac is not supported.
  2. Open the flip and turn the phone on.
  3. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  4. On your phone, press Yes to use the phone as a portable USB storage device.
  5. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon
  6. Double click the Mass Storage Device icon.
  7. Drag and drop files between your computer and phone
  8. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware" icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  9. Select USB Mass Storage Device and click OK.
  10. Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts.
Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
HELP MEEEE!!!
You need to reprogram your phone. If you have the usb cable you can do it yourself.
http://direct.motorola.com/Hellomoto/uk/support/SoftwaresNDrivers.asp
    Note: Mac is not suported.
    NOTE: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  5. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
  6. Drag and drop files between your computer and phone.
  7. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
  8. Select USB Mass Storage Device and click OK.
i found this on a another fellow fixya member's page.
Have a nice day!
1helpful
2answers
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
  6. Select USB Mass Storage Device and click OK.
Usb port
Hey!
First u hv to install software that came with as CD. It's easy to install , jst select the location & recommand yes option. But remember while installation USB cable should be unplugged. At th last stage it required connectivity betwn ur pc & mobl. & check in ur mobile there is USB Mode options in ur setup menu. 1. USB Modem
2. Mass storage
click on USB Modem & save it.
After instaln of softwr a new screen will appear. Pl. click on internet button it will connect through ur GPRS automatically.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
